brmurph
12-01-04, 08:38 PM
Dealer is replacing my shocks and starter total cost of $2300.00 (thank goodnes for extended warranties). According to the factory manual I have there is an air dryer that is part of the compressor assembly, should this dryer be replaced at the same time that the shocks are replaced? I think the part only runs about $100.00 seems like cheap insurance to protect such expensive shocks. My assumption is that the dryer must dry the air that gets pumped into the shocks, anybody know if this is true? They also show an air filter for the compressor, should this be replaced as well?
The dealer said the dryer and the filter hardly ever go bad so there is no need to replace. To me that thinking is off, I would think the dryer and filter protect the air that goes into the shocks (and compressor)?
Any thoughts?
Krashed989
12-01-04, 10:00 PM
Are you sure that it has a filter and a drier... it kinda sound to me like you are confusing the A/C compressor with the shocks' air compressor, because i know the a/c has a filter/drier near the passenger side shock tower under the hood but this is the first i've heard about the shocks having them... You might be right though that the shocks have them because i dont really know.
brmurph
12-01-04, 10:57 PM
According to the factory manual there is also one for the compressor for the shocks. I am aware of the dryer for the AC, thanks though.
DaveSmed
12-02-04, 01:21 AM
Not sure if the 98's compressor is the same, but the earlier ones it was the black canister on the compressor. It also acted as an accumulator too. You shouldn't need to replace it, the desiccant rarely gets saturated to the point of being unusable. If you are really concerned about it, you wouldn't by any chance have a vacuum pump would you? 29" of vacuum would boil out any moisture in there pretty quick.
brmurph
12-02-04, 01:41 PM
Good thought on pulling a vacuum, that would verfiy for the short term anyway.l Thanks
cadibrougham
12-02-04, 11:57 PM
Im Shocked That The Dealer Isnt Trying To Sell You That Even Though You Want It Sounds Very Interesting To Me. What Dealer Is This What State. Sounds Like An Honest Dealer.
brmurph
12-03-04, 12:36 AM
Covert Cadillac in Austin TX. So far I have had great service, they have always done a good job troubleshooting problems for me instead of just swapping parts and running up the bill.
