: 275 40 r19
maybe2fast
06-20-12, 11:23 AM
This size seems alot more common is it useable? in the rear
thebigjimsho
06-20-12, 09:02 PM
You might want to do a 245/45 19 front tire, then...
maybe2fast
06-20-12, 10:55 PM
are you being sarcastic or does that regulate the diameters?
Low_ET
06-21-12, 06:47 PM
That size will fit just fine. It will make your speedometer read about 2 mph lower (at 60 mph). It looks to me like the stock 285/35/19 is about the same price as the 275/40/19. When in doubt, I would go with the stock wider size.
thebigjimsho
06-21-12, 09:17 PM
You don't want different rolling diameters from front to back. So if you want that size in back, you'll need to change the front...
embassured
06-24-12, 01:53 PM
I'm running 245/45s up front and 275/40s in the rear as I switched to (gasp) all-season (Conti DWS) tread.
The width difference between stock and the above size is nominal; i.e. a 1/3rd of an inch less. While I "theoretically" don't like the increased sidewall; I: 1> rarely even push the car to 80% of its handling limits and 2> the increased sidewall does actually decrease the fender gap, which I think looks better.
That said, if there had been an all-season alternative in stock sizes I would have gone that route for the simple reason to stay stock.
Good luck,
Eric
thebigjimsho
06-24-12, 06:40 PM
Good luck,
EricWhile I wouldn't want to sacrifice that much in good weather, those would be my choice for a little extra traction in New England winters.
embassured
06-24-12, 07:39 PM
I'm in the mid-west, so half the year we have temps consistently below 50 degrees but with very little snow - maybe 3 or 4 times a year. Dedicated snows seem like overkill but but I still need decent traction when the PS2s felt like hockey pucks + a little snow protection is a must. The Jack of All Trades - Master of None fits our weather and how I drive the car. The tread wear rating DWSs isn't bad on the wallet, either!
Eric
Cub Cadet
06-28-12, 12:57 PM
The 275 wide tire needs to be on the *front*. The best sizing arrangement for looks AND performance is a 275 wide front and a 295 or 305 rear. The factory width is already too narrow for the stock wheel widths. This was done to eek out the very last, smallest amount of G-grip. Not worth it in my opinion. It made the car look cheap and ricer-ish. I changed mine out for these sizes and could not be happier. It has better performance than stock!!
thebigjimsho
06-29-12, 10:53 AM
Dear lord, not again...
