View Full Version : 1986 Cadillac Fleetwood PCD/Wheel Fitment.. 5x115?
Tee1
06-19-12, 05:38 PM
Hi guys, I've searched on net but can't find a definitive answer. Is the wheel fitment for my car 5 stud x 115? If so I'm assuming I can use 5x114.3 wheels with wobble bolts which will make up the slight difference in bolt distance. Reason I want a change is the current wheels are too narrow!
Also while I'm here, any idea what the biggest size is I can put on? Ta for any help in advance.
Tee1
06-20-12, 05:31 PM
Come on guys! Also what is the maximum wheel size I can run? I'm thinking about 255/45/18's, anyone running these or bigger?
still_walkin
07-16-12, 04:17 AM
OK 18s you can do but remember its a fwd car so you turn and roll on your front tires .so your gonna need to beef up your suspension. Also you on a air ride so if you struts go out there's a good chance your gonna rubb. But you factory is 205 70 14 so 255 is way higher of a tire .my advice rims do look nice on caddys but if its a everyday car throw vogues on it and call it a day.
