: Wheels / Tires HI | ADV.1 Wheel SALE! FREE Shipping to lower 48 States!
Paul@HoweyIndustries
06-18-12, 01:30 PM
Howey Industries is the largest source for ADV.1 Wheels in the Chicago, IL area. Howey Industries is also considered the Premier online distributr of ADV.1 wheels.
ADV.1 is the industry's leading Forged wheel manufacturer.
ADV.1 Wheels are available in multiple configurations. Below is a list and description of each configuration:
93586
3 piece / standard concave profile
profiles ranging from minimal concave depth of about 0.5" to roughly 2.5" maximum concave depth.
unlimited lathe profiles within the limitation of the forging and applicable for use on nearly any vehicle.
standard 3 piece "flat" lip design.
diameters 18-24 with smaller or larger diameters also available as special order. Widths 5.0-15.0+
forged aluminum inner / outer rim halves supplied by ARS or Triangle exclusively using only US materials & manufacturing.
60/61-t6 heat treated forged aluminum center discs supplied exclusively by ASA or Centerline using only US made materials & manufacturing.
93587
3 piece / deep concave profile
the industry's original deep concave forging, developed by ADV.1 in 2009.
provides a deep concave profile up to 5" for some applications, depenging on the vehicles offset limitations.
deep lip application using ADV.1's "leg extension" option which gives the aggressive deep concave profile while at the same time allowing for a deep lip size.
the deep concave / minimal lip option provides a lighter weight, minimal style wheel with an aggressive, deep concave profile up to 5.0" for some applications.
diameters 18-24 without leg extension option and 19-24 with leg extension / deep lip option. Widths 5.0-15.0+
same US made forged aluminum parts used on all ADV.1 3 piece wheels.
93588
3 piece / track spec
another industry design breakthrough by ADV.1, designed in early 2010 and released at the 2010 Sema show, the Track Spec line has since become one of, if not THE most sought after wheels on the market.
provides the combination of lightweight, high strength forged aluminum step lip rim halves with our deep concave forging profiles.
contoured spoke profile gives the appearance of a larger diameter wheel which was previously lost in a step lip configuration.
eliminates the unavoidable water retention issue found on standard "flat lip" 3 piece wheels.
93589
3 piece / TRAKfunction
our version of "entry level" which in reality isn't entry level at all in comparison to other wheel brands competing for this price point. The term "entry level" only pertains to the Trak Function line being ADV.1's entry level 3 piece wheel, however still it remains one of the highest quality options in it's price range.
uses a template based engineering process rather than our other 3 piece wheels which are individually engineered without any set guidelines. allows for faster production and lower cost.
pre-lathe programmed / non concave profiles allowing for a deeper traditional style step lip or flat lip (S Function) design.
lightweight, strong and uses the same ADV.1 quality and materials found on all of our forged wheels.
diameters 17-22. Widths 5.0-15.0+
93590
1 Piece / Forged
We offer the largest 1 piece forged program on the market today. With over $300k in aluminum forging inventory we're able to make a 1 piece forged version of all of our wheel styles, for any application, in multiple sizes & even multiple profiles.
Offers a more oem style than a 3 piece wheel would however with a more aggressive stance, concave profile and custom finishes.
Available in all custom finish options and custom engineered to order using any preferred offset and / or profile preferred.
diameters 18-23" / width 8"-13" - see technical spec page for more details.
93591
1 / 3 piece ADVX program
For the first time in the history of aftermarket wheels, a company has the ability and engineering freedom to allow YOU to design your own individual wheel style. A custom built, specifically engineered wheel is always limited to the wheel style selection offered. Finally we're proud to allow our clients the ability to design their own wheel style. Available in any size, finish, & configuration offered by ADV.1, the ADVX program is the ultimate custom wheel.
The process is available as a propietary design not to ever be offered again or as a non propietary design which may be purchased later by other customers.
Design is performed directly with our lead Engineer, Tom Van Ryn & President / designer Jordan Swerdloff.
93592
1 & 3 piece / SL series
The ADV.1 Track Specific forging configuration is our answer to the popular question, "so, how much do they weigh?" Many of our wheels are already competitively lightweight as it is, however for our clients who demand performance we've developed the track.one lineup. The only truly vehicle specific, tested, lightweight wheel for excessively powerful, 200+ mph, 2000+ horsepower exotic vehicles.
sub 20 pound weight class in most cases where applicable.
fully tested for race / street use.
available in sizes 17-22" 3 piece forged track spec onfigurations.
available in sizes 18-22" monoblock forgings
93593
1 & 3 piece / Track Specific SL series
SL Series, meaning super light is ADV.1's lightweight version of all existing styles in both 3 piece Track Spec & 1 piece forged configurations. The SL engineering modification combines weight reduction techniques with aesthetic enhancements in order to provide a lightweight version of the non SL modified style. The standard SL series wheels are lightweight, high strength performance wheels designed for high performance applications specifically.
fully tested for race / street use. Includes our titanium plate SL series test documentation / identification badge.
individually engineered to order.
ADV.1 Wheel Models (Available in the above configurations):
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV5.0/ADV5-0DC/7.jpg
ADV5.0
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV5/ADV5/1.jpg
ADV5
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV05/ADV05/1.jpg
ADV05
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV5.2/ADV5-2/1.jpg
ADV5.2
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV6/ADV6TS/1.jpg
ADV6
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV6.0/ADV6-0TS/1.jpg
ADV6.0
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV08/ADV08TS/1.jpg
ADV08
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV8/ADV8/1.jpg
ADV8
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV10/ADV10DC/1.jpg
ADV10
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV7/ADV7DC/1.jpg
ADV7
http://www.adv1wheels.com/adv1wheels/wheelcollection/ADV07/ADV07/1.jpg
ADV07
Lead Time: ADV.1 Wheels are built to order and take 4-6 weeks to manufacture. Howey Industries will assist you with the perfect offset to accommodate your vehicle's suspension modifications, brake upgrades, and/or specific tire sizes. We build every wheel to fit your precise needs.
Shipping/Delivery: We are currently offering FREE SHIPPING on all ADV.1 orders within the United States. All ADV.1 orders are shipped via UPS or FedEx Ground unless otherwise specified and require a signature upon delivery.
Payment: Howey Industries accepts Visa, MasterCard, Discover, American Express, and PayPal. Howey Industries only requires a 50% deposit on ADv.1 orders. The remaining balance is due prior to shipment.
Contact: We are available by phone at: 1-888-554-7755, by email: sales@howeyindustries.com or paul@howeyindustries.com, online: www.howeyindustries.com (http://www.howeyindustries.com), and by PM.
06-20-12, 05:00 PM
Check out this CTS-V Coupe w/ ADV.1 ADV08SF Wheels!
http://www.adv1wheels.com/adv1wheels/advgal/cache/chevy/chevy-cadillac-cts-v-adv08sf/adv1blackcts-v10_w1200.jpg
http://www.adv1wheels.com/adv1wheels/advgal/cache/chevy/chevy-cadillac-cts-v-adv08sf/adv1blackcts-v8_w1200.jpg
http://www.adv1wheels.com/adv1wheels/advgal/cache/chevy/chevy-cadillac-cts-v-adv08sf/adv1blackcts-v11_w1200.jpg
Paul
06-21-12, 11:32 AM
Another Amazing CTS-V rolling on ADV.1 ADV10DC Deep Concave Wheels!
http://i1247.photobucket.com/albums/gg639/ADV1Images/ADV1WBRedCTS-V2.jpg
http://i1247.photobucket.com/albums/gg639/ADV1Images/ADV1WBRedCTS-V3.jpg
http://i1247.photobucket.com/albums/gg639/ADV1Images/ADV1WBRedGTS-V1.jpg
07-09-12, 08:56 PM
All PM's replied to!
10-16-12, 01:51 PM
End of Season Sale! Contact us for special pricing!
niknik
10-21-12, 01:43 PM
Hi! I need a set of 18 inch 6 lug OEM rims for my 04 SRX AWD. Do you have any available&can you please send me a quote? My email addy is nikita_rog@yahoo.com
Thanks in advance.
03-31-13, 02:26 PM
SPECIAL EASTER WEEKEND/WEEK PRICING!!! Don't miss out!!!
04-19-13, 05:33 PM
New pricing and new models! PM for details!
