View Full Version : Air conditioning problems in 2005 STS V8
lvilla03
06-14-12, 12:50 PM
Ok soooooo this is weird. This morning I start up the car to go get some gas before work. The A/C was blowing cold! The "auto" was on for both fan and ventilation. I turn the car off to pump gas. Turn the car back on A/C is running no problem. About a mile down the road I decided to smoke a cig. Open up the sunroof and turn off the A/C I then finish my cig and hit auto. The A/C turned on but did not blow out barely any cold air. The air coming out was cold but nothing was really coming out the dashboard vents. Sounds like something is clogged through the passage to coming out. The feet blow out fine as well as the defrost.
Sorry for the long message an I'm sure a lot of it could have been taken out. I just wanted you guys to know every detail. Thank you!
Cadjiek
06-14-12, 01:41 PM
Sounds like it could be Emphysema from the cigs??
lvilla03
06-14-12, 02:06 PM
I guess lol.
1BadCadSTS
06-14-12, 02:20 PM
Is the snowflake lit on the display?
lvilla03
06-14-12, 02:26 PM
No. It's not. It's just theres no airflow coming through the vents. Like barely blowing through. Like its clogged
1BadCadSTS
06-14-12, 02:53 PM
Sounds like u blew the blower motor. Does the rear hvac blow cold?
lvilla03
06-14-12, 03:42 PM
Yeah the rear blows no no problem. But how can I blow the motor if the feet blow no problem.
lvilla03
06-14-12, 04:02 PM
And also. Cold air blows out the dashboard vents but it's very faint. It honestly appears to be clogged
caddyfat2
06-14-12, 08:22 PM
Stop smoking those left handed cigarettes!!!! LOL but seriously check your air setting to make sure they are in the proper mode to do what you want.
EChas3
06-14-12, 08:35 PM
I think there are two blowers to provide the personalized climate control. Whether there's one with vent controls or two, blowers are now driven by IC's. You likely need diagnosis according to the shop manual procedures. Alldata may suffice.
lvilla03
06-14-12, 09:19 PM
Lol. Your funny
lvilla03
06-14-12, 09:20 PM
Sooo I get off work and hit my remote start to cool off the car and to check to see if there was still a problem. I dunno what happened but the cadi fixed itself lol. The was airflow through the vents. Thank you guys for the help and ideas.
lvilla03
06-14-12, 09:21 PM
*there was....
andya222
06-14-12, 09:38 PM
If air was flowing good to the floor and light at the vents then you may have a mode door actuator that is starting to go out. If i happens a few more times in the future you'll want to have a diagnostic scan done on the hvac system to check for proper movement on that door in the evaporator case.
EChas3
06-14-12, 10:15 PM
There is still that old 'farting' vent door syndrome.
lvilla03
06-15-12, 10:12 AM
Ok.. That makes sense. Thank you!
lvilla03
06-15-12, 10:13 AM
I guess lol
scott9001
06-15-12, 06:21 PM
check your cabin air filter also!
dkozloski
06-17-12, 10:36 AM
When all else fails, push the "Auto" button. This car is smarter than most owners.
