View Full Version : 2011+ Fender Vent into a 2010 or 2009
Bigron
06-09-12, 12:58 PM
I did a quick search and could not come up with anything definitive or a DYI.
I sent Luke a note, but what is the going rate and what are the part numbers?
How do you remove the current one and is the process reversable or do you destroy them in the process?
Thanks for the help,
Ron
M5eater
06-11-12, 05:22 PM
you can open the hood and see how it's secured from behind for starters.
Bigron
06-11-12, 06:24 PM
Thanks for the advice. Since I had not removed the plastic surround I was not aware that you could access them from there.
M5eater
06-11-12, 07:26 PM
yup, open the hood, you can get a very good view of them. They *are* supposed to be functional fender vents afterall ;)
Bigron
06-12-12, 07:12 AM
Are the CTS and CTS-V the same?
larry arizona
06-19-12, 12:30 PM
Bigron, I think the vent is the same for the V and other. It appears that the 2009/2010 is different than the 2011/2012. The 2009/2012 have a chrome crossbar in the center of the vent and its open in the middle on the 2011/2012.
Bigron
06-21-12, 09:52 AM
Yeah the CTS and CTS-V vents look the same.
Maybe more air into the engine bay getting rid of that crossbar :)
Also, update the look and I might black it out.
Jon
06-27-12, 01:43 PM
I did it on my '09. Pain in the ass as there are 2 tabs you have to break on each of the vents. Easy to scratch your fender.
Dr. Design
06-27-12, 06:54 PM
Hello Ron,
We have done a ton of these swaps. They are the same fenders so you can swap them without issue. The mounting tabs are a PITA. Your new OEM vents will come with panel attachment tape for install.
Thank you,
Dr. Design
D3 Cadillac
Ron
