I just found a great deal on a C5 Z06 clutch/flywheel set up for $150 brand new. Has anyone used this set up in a V before? If so, what slave did you use? I'm just asking since I can't find much literature on google about this.
That's the LS6 clutch that's in your V, but with a thinner/lighter flywheel if I'm not mistaken.
If you use the stock slave, you will have to shim, or you might be able to use a LS7 slave.
Only way to know for sure is to measure.
That is a great deal if you're installing it yourself, otherwise I would get a least an LS7 setup in there.
My clutch isn't bad yet, but for $150 I figured it would make a good spare.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
