: need to find fuel sending unit for 1992 cadillac sts 4.9
05-30-12, 08:05 PM
heard they were discontinued but was hoping there was one out there somewhere still just wanted help in finding if so thank you
gas gauge reading empty and range reads 0 i just replaced fuel pump i think float might be stuck or bad connection ,will check in the morn
but possibly need new for back up just in case needed thanks p.s worked fine for 5 min from shop to gas station but after fill gauge went
to empty thanks again are there any other units i can use for this model and year
05-31-12, 11:43 AM
they are discontinued with no stock available at any dealer nationwide
I checked some aftermarket brands and it doesn't look like anyone carries it either
sorry for the bad news, but it looks like you'll have to go with a used one
looks like the 1992 Toronado, Reatta, Riviera, Eldorado & Seville all used this same sender
good luck
Try cadillacheaven.com if you can't find a good one locally
05-31-12, 12:00 PM
thanks for the info
