View Full Version : Oil Change-When?? Every xxx miles or Oil Life%
doctorwill
05-29-12, 08:23 AM
I have a 2008 Escalade AWD with 55000. I am curious as to when I should change the oil. I have gotten different advice from different dealers or service managers....
When should I change my oil? Should it be every xxxx miles base, if so how much 3000,5000,7500
How accurate is the oil life monitor? Should I base my oil change on % of oil life remaining?
( Some dealers suggests to wait til it gets to below 30%)
Finally, what oil should I use? Synthetic, Synthetic Blend, or regular
Thank you for any advice...
Will
hcvone
05-29-12, 09:51 AM
Will
GM puts synthetic oil in all Caddy's, think since 2009 I believe, if you are using synthetic oil in the engine I would change it every 7500 or 1 year, if you are using regular oil I would change it every 3k miles and switch to a synthetic oil even Mobil 1 is a good choice, that is what GM uses in the engine of new Caddy's
corvette00
05-30-12, 08:23 AM
I would go by the sensor, my guess it will indicate a change is needed around the time Carl suggested.
Nice Ride
05-30-12, 08:53 AM
I change my oil once a year regardless what the DIC displays. I only put on about 12k per year. Ask 10 people, get 11 different answers.... Don't forget to check the oil level if you do decide to wait, lots of people never check the oil level and just go by the DIC. Oh, and be careful closing your hood, the sheet metal is paper thin and dings if toy look at it the wrong way....
rjm
05-30-12, 01:12 PM
I've always changed the oil when the car tells me. I've been doing this since GM/Cadillac added the oil life monitor. Granted all my cars have been acquired on 2 or 3 year leases, but still I've always waited until the oil monitor said "Change Engine Oil". Even in the Northstar equipped cars, although I would periodically check the oil level as that engine was notorious for leaking/oil consumption.
RippyPartsDept
05-30-12, 01:49 PM
if you want the short answer: use the recommended oil in your owners manual and go by the OLM ... change it whenever you feel comfortable ... i usually never let it get below 5%
continue reading for the long answer
http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/125545-engine-oil-myths-including-zdp-gm.html (http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/125545-engine-oil-myths-including-zdp-gm.html)
lots of good reading there ...
but the most important read should be this one:
(found in various places online but originally written by our old forum guru (http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/212706-cold-carbon-knock-thought-i-ate.html) - a GM powertrain engineer who worked on the NorthStar)
One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life montitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. NOt something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
Please...NOT ALL ENGINES ARE THE SAME. The example above is an excellent practical justification of why you would want to add EOS and change the 15W40 Delvac in the muscle car at 3000 miles max and yet can run the Northstar to 12500 easily on conventional oil. You must treat each engine and situation differently and what applies to one does not retroactively apply to others. This is where Amsoil falls short in my book by proposing long change intervals in most everything if you use their oil. It just doesn't work that way. You can run the Amsoil to 12500 with no concerns whatsoever in the late model Northstar because even the oil life monitor tells you that for conventional oil off the shelf. Would I do that to the 502 in my 66 Chevelle...NO WAY. Amsoil says I can though. Wrong.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.
also, another good oil change discussion
http://www.cadillacforums.com/forums/2008-cadillac-cts-general-discussion/171121-09-cts-awd-3-6-oil.html
there's ton's of them on this site ...
48Dodge
05-30-12, 02:51 PM
Best description.
Ghost Deany
05-30-12, 03:05 PM
I always do every 3k.
