View Full Version : Does the leather LeBra for the CTS fit the V? (want a temp solution for long trip)
sybersport
05-26-12, 04:34 PM
I'm going to be taking my V on a long road trip, and want to minimize damage to the front clip. I'm only going to use it for this trip (and perhaps other road trips in the future), and I don't want to install a clear bra.
Will the leather LeBra made for the CTS fit? I found a listing on Ebay that says it will fit the V...
http://www.ebay.com/itm/LeBra-Front-End-Cover-STOCK-2008-2012-CADILLAC-CTS-Mask-Bra-551205-01-/230680930155?fits=Model:CTS|Submodel:V&hash=item35b5a7a76b&item=230680930155&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Thanks
thebigjimsho
05-27-12, 11:00 AM
I would just do a 3M clear bra and be permanently free of worry...
VMoose
05-29-12, 03:07 PM
What's the average cost of a 3M clear bra?
thebigjimsho
05-29-12, 10:42 PM
To do the front end and side mirrors should run from $5-600...
M5eater
06-01-12, 08:46 PM
you want a temporary bra?
http://www.duplicolor.com/duplicolor-weblogic/products/shield/
and no, the leather bra will not fit.
me personally, I didn't want a clear-bra because I didn't like the way it looked. I suggest you find a car with one and decide for yourself.
a $500-600 install is going to be a precut kit and it's going to be by a average/sub average installer that's probably going to screw up in 1-2 spots. If you're OK with that and prefer overall protection for show-room looks all the time, the clear bra is the way to go.
Thunder Gray STS
06-03-12, 10:24 PM
I am currently on a long trip 4500 miles. I ordered 2 cans of clear plasti dip and coated the nose of the car. Took bout an hour. I didn't try to do the neatest job because I knew I was just going to peel it off when I got back. Working like a charm so far. Cost 14 bucks.
thebigjimsho
06-03-12, 11:16 PM
I am currently on a long trip 4500 miles. I ordered 2 cans of clear plasti dip and coated the nose of the car. Took bout an hour. I didn't try to do the neatest job because I knew I was just going to peel it off when I got back. Working like a charm so far. Cost 14 bucks.Could you get some pics? Or is it imperceptible??
Thunder Gray STS
06-03-12, 11:48 PM
I don't think the camera could capture it. It slightly dulls the covered area. I will try to get a picture in the morning. The front of the car is covered in bugs. Something funny about that is a couple of birds were hanging on to the mesh of the grill and picking bugs off for breakfast this morning, never seen that before.
Thunder Gray STS
06-04-12, 11:34 AM
Here is a picture of an area where it pulled off when removing the tape. It's the only place on the car where the camera can see the difference.
M5eater
06-04-12, 04:09 PM
Nice. that stuff almost looks like clear bra. My only concern with these spray-on bra's is that you need to tape everything off evertime you want to use it. Good for long-distance trips once or twice a year, but I could see it becomming a chore for anything more often than that.
sound about right?
neuronbob
06-04-12, 04:39 PM
If you care about your paint under the leather bra, especially if the bra gets wet, you will not use a leather bra. If your car is leased and you don't care what the paint looks like at turn-in time, the by all means use one.
Otherwise, just use a clear bra or the plastidip alternative noted above. I use a clear bra and it looks great while offering great protection. Worth every penny IMHO.
thebigjimsho
06-04-12, 05:08 PM
Good points, all.
Thunder Gray STS
06-04-12, 05:46 PM
sound about right?
Sounds about right. It only took about an hour to tape everything off and shoot it. Definitely not anything permanent. Like I said before I didn't even attempt to be real neat, since I will peel it off as soon as a get back home... Got 2000 miles to go.
M5eater
06-04-12, 06:35 PM
I think I may try some for track days. Looks better than blue painters tape!
Thunder Gray STS
06-04-12, 07:14 PM
Just make sure you get a heavy coat. Doesn't have to be even, just heavy. Otherwise you will need some sort of solvent to remove. Plasti Dip isn't very robust against solvents.
Torxila
06-07-12, 05:16 PM
"Road-Wrap" at California Car Cover Co. Not sure If I'm allowed to post link?
Cheep and seems like a good idea. I just ordered both 6" and 18" rolls. Going to use it on my next trip.
George
sybersport
06-12-12, 02:17 AM
I ended up PlastiDipping the front end, in Clear. It worked out quite well.
I do have a problem now... I didn't lay it on thick enough in some areas, so it won't easily peel off..
Is there any product I can use to dissolve it, that won't mess up my paint?
Thunder Gray STS
06-12-12, 07:59 AM
Yep, plain old rubbing alcohol and a micro fiber cloth. Don't have to rub hard, but it takes about a minute to dissolve it. A little wax chaser over the area and done.
