View Full Version : Front aux power/Cig lighter outlet has no power.
pick
05-26-12, 12:40 PM
Lost power to my front outlet running an airpump for my kids bicycle. Checked fuse block and all fuses good. Any ideas before I remove the center console?
TAM79
05-29-12, 12:25 PM
I had the same problem on my EXT, check the fuse box under the dash or open the drivers door and pop the cover off there is an aux pwr fuse there also!
48Dodge
05-29-12, 02:09 PM
When I got my ESV, all outlets had burned out. (4 total, I think). I know there are at least 2 different fuses for them, maybe 3
franknitty69
10-18-14, 01:50 PM
the same exact thing just happened on my 08. running an airpump and it cut off. i checked all aux pwr fuses inside (drivers left) as well as under hood #53. all fuses are fine. i even replaced them to rule that out. i popped open the center console and the wiring is fine, the plug is fine. the cigarette lighter just stopped working. is possible that the cigarette lighter itself is bad.
franknitty69
11-06-15, 02:50 PM
1 yr later and still doesn't work. i replaced the cigarette lighter...same problem.
