: How to remove Clutch Pedal Assembly?
05-22-12, 11:56 PM
So, my bracket that holds the clutch master cylinder broke.... Sheered in one spot and now will no longer retain a master cylinder.
New pedal assembly/bracket in hand.
The problem is that the 2 bolts securing the assembly are WAY up in a mess of brackets, wires, and other miscellaneous crap.
I can't seem to get at the bolts with much room for box wrench movement. Sockets won't fit up there as the e-brake is in the way.
I'd like to remove as few components as possible. Are any FSM scans or tips/tricks to removing the clutch pedal assembly?
Any and all help is greatly appreciated!!
After more searching found this:
Thanks Darkman!
Looks like the parking brake must be removed (no being lazy...)
I'll have to get under there again tomorrow after work and before dusk to see if I can get that e-brake out of there.
Any drawings with bolt and nut locations for the parking brake would be appreciated!
05-23-12, 12:00 AM
I am not sure these will help, but... see attached.
