: Spoiler Install --- Drilling Holes --- Pics
BarrySTS
05-22-12, 06:21 PM
I purchased a spoiler from http://www.ebay.ca/itm/280611459426?_trksid=p5197.c0.m619 several months ago and did not install it until recently. I finally got up enough courage to drill holes in the trunk lid. I know others have used double sided tape to install their spoilers, I guess I never felt comfortable in doing this. I kept imagining driving on the highway and hearing a "thung" noise and looking in the mirror to see a spoiler bouncing along the road behind.
Here is a summary of the installation, with pics.
Drilling the holes...
- Made a template from cereal boxes. Punched the holes first, then when all holes complete, lay the template on the spoiler and cut the template to the exact outside dimension of the spoiler.
- Lay the template on the trunk in the desired position and tape in place.
- Where the stud holes are in the template, I stuck tape directly under, on the trunk lid, easy to mark the holes for drilling.
- With the holes marked, remove the template.
- Drill the holes in the trunk !!!!!!!!
- Test fit the spoiler to the trunk. (I needed to lightly file two holes to get an easy fit)
I also primed the bare edges of the drilled holes. (Sprayed some primer in a bottle top and uses an artist brush)
Important!!
The inner structure of the trunk is pre drilled to allow the installation of the nuts/washers to fasten the spoiler. HOWEVER, the outer most holes (one on each end) in the trunk lid are not aligned with the studs in the spoiler. These are the only studs in the spoiler that are not "factory" correct.
You need to drill a 1" hole in the inner trunk to facilitate installing the nut on the outside studs. I purchased 1" plastic plugs from NAPA for 18 cents each to cover the 1" holes. The plugs need to be there as this area is exposed to the outside.
Installation....
- Use a sealer on the studs. I made sealer donuts and placed around the studs on the spoiler.
- Place the spoiler on the trunk, studs thru the holes.
- Make sealer donuts for the nuts/washers and attach all nuts/washers, tighten lightly until all are installed. Then snug all the nuts, squishing the sealer donuts.
- Install the 1" plastic plugs in the outer holes with lots of grease/undercoating to protect the newly cut hole. Wipe clean.
Observations....
- The spoiler appears to be of excellent quality.
- The spoilers are pre painted, excellent quality and color match.
- I set the spoiler slightly more rearward than the stock location. I just liked it better there.
These spoilers are an amazing value. I don't understand why he hasn't sold all of them by now. A great guy to deal with, he even sent me extra pictures so I could compare the color.
http://users.eastlink.ca/~chappell/SpoilerPics/100_4142.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4143.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4144.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4145.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4146.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4147.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4148.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4151.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4156.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4159.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4160.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4161.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4165.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4168.jpg
http://users.eastlink.ca/~chappell/SpoilerPics/100_4169.jpg
N*08STS
05-22-12, 06:43 PM
Wow. Nice right up. Spoiler looks great in pics, does it look just as nice up close? $30 plus $43 shipping, I may have to give that a try, the drilling holes may cause me to go weak in the knees...lol. I've only had mine about two weeks know. Does the spoiler make a big difference in look to you, versus not having one.
1BadCadSTS
05-22-12, 08:37 PM
My 05 awd has one and in 07 awds had rear spoiler deleted no idea why but as such my dads 07 doesn't. I think it looks stupid without one IMHO.
BarrySTS
05-22-12, 08:47 PM
The spoiler looks very nice up close. The paint job is excellent. The color is slightly darker than the lid top and seems to be exact on the trunk rear. I have always liked the look of the STS spoiler. It did take almost 6 months for me to get up the courage to drill holes in the trunk.
The trunk lid is aluminum and the holes drill very easily.
1BadCadSTS
05-22-12, 09:03 PM
92439
Love mine. 05 1SG full gm accessory tails and corsa.
DarkMingBlueSTS
05-22-12, 11:02 PM
Looks good!
Ludacrisvp
05-23-12, 10:35 AM
Looks good.
And For around $70 US already painted to factory color it may not be a bad idea. .... I may have to pick one up too, once I confirm what colors he actually has available.
@1BadCadSTS - Does the spoiler on yours (that I assume is factory installed) sit flush with the back of the lid?
This is the best pic I could find showing what I am talking about (I realize its a different spoiler, I am just looking at mount location)
http://www.carid.com/images/eg-classics/spoilers/5006-1700-05xsb-close-up.jpg
1BadCadSTS
05-23-12, 10:53 AM
That spoiler looks like the e&g high rise (a blend between the v and standard STS spoiler). Mine sits flush but not at the very edge. Again mine is factory installed.
Ludacrisvp
05-23-12, 01:12 PM
Yes, that is the E&G STS Spoiler they call it 'Version II' on the CarID website. I did hear back from the seller and they dont have the spoiler pre-painted in my color.
That is the info I am looking for is how close to the edge it is supposed to be. But since they don't have my color I guess its a moot point. I am fond of the E&G version II spoiler as it reminds me of the "NASCAR Inspired" spoiler that came equipped on my '01 Monte Carlo SS High Sport. I suppose I'll just keep an eye out for a good deal, whether its the factory non-v or V or E&G V2 if I get a good deal I would pick one up.
To the OP: I can't imaging what it would be like to be drilling into the lid... sounds very nerve racking.
1BadCadSTS
05-23-12, 01:23 PM
The v spoiler isn't drilled. It's tape mounted I believe.
I'll take more pics of mine later. The forum app sucks for pics off my iPhone they are always too big to fit.
Ludacrisvp
05-23-12, 02:06 PM
I agree with that completely! I use camera+ and take pics then have the app upload them to flickr then link them in that way.
1BadCadSTS
05-23-12, 03:40 PM
Here it is.
1BadCadSTS
05-23-12, 03:47 PM
Another angle
Ludacrisvp
05-23-12, 05:09 PM
Looks real good, an looks like the OP got it in the same place too.
1BadCadSTS
05-23-12, 06:11 PM
Thanks and yup looks spot on.
zek4964
05-25-12, 03:11 PM
Wow you have giant balls I dont think I would do it myself but it looks great nice job! Drilling holes in the trunk gives me the willies just thinking of it. I consider myself pretty good with tools but just would not want to screw something like that up.... Nice job looks good I want one!!!
oupavoc
05-29-12, 03:19 PM
Very nice work...thanks for the right up :)
KRSTS
02-17-13, 06:19 PM
[QUOTE=BarrySTS;2975112]The spoiler looks very nice up close. The paint job is excellent. The color is slightly darker than the lid top and seems to be exact on the trunk rear. I have always liked the look of the STS spoiler. It did take almost 6 months for me to get up the courage to drill holes in the trunk.
The trunk lid is aluminum and the holes drill very easily.[/QUOT
Just found your old post Barry. I also bought the same exact spoiler from him and still have not gotten the courage to drill the holes in my trunk lid. After reviewing your post again, I think I will do it when the weather improves. I also noticed that the color was slightly off but you say it is not noticeable on the car? Where dis you get the nuts that fit the studs? Thanks for your wonderfully detailed instuctions.
Ludacrisvp
02-17-13, 06:56 PM
I brought my spoiler down to the hardware store and just test fitted a bunch of random nuts until I had the right size that matched threads properly; bought 10 of them and some washers and got the nuts that had the self locking mechanism built in them.
BarrySTS
02-18-13, 11:41 AM
The difference in color is very slight. Since the spoiler is slightly darker it's not noticeable, especially outside, as sun and shadows make the entire car appear lighter and darker depending on your viewing angle.
The nuts I used are stock GM nuts that have the washers attached to the nuts. They were metric, however not sure what size, looks like 1/4". The sealer I used around the spoiler studs and under the washers came from a auto windshield shop. It's like play-doh, and never hardens.
05STS4V8
02-20-13, 02:40 PM
92439
Looks like mine. What isnt stock on this pic? im new to the forum
Ludacrisvp
02-20-13, 02:46 PM
He has the 3 optional GM Accessory tails. Long since discontinued. Most STSs out there have all red tails.
Those are smoked with all red LEDs, compared to Euro that look very similar but Euro have Amber signals and a few more LEDs on them.
05STS4V8
02-20-13, 04:43 PM
ahh ok. I notice it now. Those would look great on my White one i think. That looks like a pricey conversion on the taillights, but well worth it! Looks great
Ludacrisvp
02-20-13, 06:03 PM
I think the set of Accessory tails were like $350 for all 3 ... 1BadCad correct me if I am wrong on that.
The Euro set runs about $400 (discounted) each and the 3rd brake light is not available in clear anymore.
