: 08 STS with Blue Tooth wont play music over radio
zek4964
05-18-12, 07:18 AM
Why is it that my car has blue tooth connection but it will not play music from my phone over the radio? The blue tooth works great for phone calls but I cant get it to play music over the car speakers while it is hooked to blue tooth. I know other cars have this capablity why doesnt it work? Also will the aux input in the arm rest councel play music. I see it is labeled as an input but it has red and white jacks for the right and left speaker input. I would need a cable to connect to the output of my phone then to the two inputs into the aux jack. Does anyone know how to get one? Or if it would work for a music input?
Ludacrisvp
05-18-12, 10:34 AM
The car only support the Bluetooth mono headset audio profile. It does not support A2DP or stereo audio headset profile. It is only allowed to be a calling headset.
Because in their infinite wisdom back when the unit was designed stereo Bluetooth music wasn't very common and therefore decided not to implement it.
Yes it will play music.
Go to radioshack and get a stereo RCA to 3.5mm phono jack (standard headphone jack) cable. Should be less than $10.
EChas3
05-18-12, 08:13 PM
Alternatively, you can add an aftermarket module. There are some available.
zek4964
05-19-12, 01:42 AM
thanks for the info that helps. I thought blue tooth was pretty much a main stay by 2008 but what do I know. I guess GM didnt think the phone was going to play music. DUH...
Ludacrisvp
05-19-12, 10:02 AM
Bluetooth was common, it's just a lot of devices didn't support streaming music.
1BadCadSTS
05-19-12, 10:19 AM
It was implemented in 2005 and basically the radio went unchanged all throughout production. Before knocking gm how about you tell me what other cars had built in Bluetooth in 2005?! I say way to go gm for having it standard in the STS with nav.
Ludacrisvp
05-19-12, 01:27 PM
And chances are it was designed in late 03 and finalized in early 04 to be ready for production run in time to produce the 2005 models.
However they could very likely update the units firmware to add this additional profile but I don't see that ever happening.
eatyoursandwich
05-21-12, 02:58 PM
Bluetooth wasn't able to stream music until Bluetooth SIG released 3.0+HS in April, 2009. An AMP (Alternate MAC/PHY) is needed which is hardware based so I doubt any firmware releases will make this possible. Much easier to just buy a cable or an aftermarket module.
I have Tomm's lockpick and use the aux outlet to plug my iphone into which lets me watch movies/videos/anything on my iphone on the head unit display -- even while driving. Obviously only while stuck in traffic of course..
zek4964
05-22-12, 11:22 AM
My car's year is 2008. Three years newer than an 05, Why did GM make no changes to the interier of the car while the CTS's interier was redone? At least they could have made the effort to update it a little bit even though they planned to stop production. I like my car but it just seems they gave up on making any changes to it after 2005.
eatyoursandwich
05-22-12, 11:42 AM
I think you answered your own question. "At least they could have made the effort to update it a little bit even though they planned to stop production."
Think of it from GM's perspective. Why spend all the money on R&D to update or completely redesign the interior for a model that was in it's final years of production?
They probably could've taken pieces from the redesigned CTS and integrated into the STS like they did with a couple of the body panels, but it still costs $$ which I guess GM thought it wasn't worth.
1BadCadSTS
05-22-12, 01:36 PM
Then sell your STS and go get an xts or CTS. What more do you want.
curtc
05-22-12, 02:06 PM
Yeah, these cars sure didn't have a long production run, what 5 years or so? It's too bad cause they are sexy cars, can't wait to get into mine in a couple of days :)
