View Full Version : D3's no stagger setup
silverstreaker
05-17-12, 11:06 PM
D3 went with a no stagger setup on their nighthawk and patriot missile cars. 295s on rear wheels on all 4 corners. What is everyone thoughts on how this affects handling? I personally love the stance but I'm concerned about undue stress on steering components turning 295's.
thebigjimsho
05-18-12, 08:11 AM
I run 18x9.5" track wheels with 275/35 18 track rubber at all corners. I was not able to detect any added understeer. That 275 track rubber is about equal in width to the stock 285s...
silverstreaker
05-22-12, 02:32 AM
anyone else running same width tires all around? pics? If I find a 20x10 aftermarket wheel I like and want to use them all around, what offsets would I need front and rear (provided I want to be flush with the outside of the car but no rub when tire tucks into the wheel well). Also, would a 305/30/20 be close to stock outside diameter?
thebigjimsho
05-23-12, 12:18 PM
That's a little bigger than stock. Optimal would be 305/25 20...
Rule12b
05-23-12, 02:18 PM
I am running the square set up tire-wise (295) although my rims are not. 19x9.5 front and 19x10.5 rear. Much much better handling in my opinion. Better grip, turn in, all around improvement on the track IMO. You asked for a pic, this is the only one I've got although I'm sure D3 will be posting more from Infineon, which was the first time I ran this set up. . .
http://i2.photobucket.com/albums/y34/Rule12b/459000_10150887650399429_603099428_9360908_4553985 87_o.jpg
Tampa2Dubai
05-30-12, 07:18 AM
Jim,
Did you have to machine the 18" rims to fit over the brembo's or were there no clearance issues? What rims are you using? There seems to be more available track rubber in 18" sizes
thx
thebigjimsho
05-31-12, 09:58 PM
Nope. TSW Nurburgrings 18x9.5" +40mm offset. I wanted the 18"s so that I could have plenty of track tire options available...
Havasusteve
06-03-12, 11:54 PM
So those are a different rim than what you were running before. What tires are those? Bridgestones R's or? Is it a 295.35.19?
Rule12b
06-04-12, 07:42 PM
Yes. Those are my track wheels. TSW Nuremburgrings. 19x9.5 front, 19x10.5 rear. 295/35/19 Toyo R-888's all around. My road wheels are OEM fronts (widened to 19x11) on the back with 305/30 Supersports and the OEM rears mounted up front with 265/35 Conti's. Spacers are needed and the proper widening limit is really 19/10.5 but I'm happy to be the guinea pig so that others may benefit :-)
http://i2.photobucket.com/albums/y34/Rule12b/_B1D8065.jpg
Havasusteve
06-04-12, 11:38 PM
I know what your OEM's are big guy....I blame you for doing mine (kidding) My car is the one that was in front of you when we caravaned to the LB Grand Prix.
Awesome pic above by the way
Steve
Rule12b
06-05-12, 12:30 PM
Steve
Ah Steve! Didn't realize it was you! Yes, it was great to get a look at that sweet back end of yours! Wait, that just sounds wrong. Hahaha
