View Full Version : Disabling DRLs on RWD Fleetwoods
DaveSmed
11-27-04, 11:43 AM
The easiest way to disable the Daytime Running lights on a RWD Fleetwood is by unplugging the DRL relay in the Relay Center shown below:
http://cadillacforums.com/forums/attachment.php?attachmentid=5230&stc=1
Alternately, You could also unplug the DRL Diode assembly, which is located above the pedals by the brake light switch as shown in the diagram below:
http://cadillacforums.com/forums/attachment.php?attachmentid=5229&stc=1
RBraczyk
11-30-04, 08:36 AM
Good Info, you may want to put this in the RWD fleetwood forum, where more people can find it. But won't it blow some sort of dash light if you pull the relay?
HotRodSaint
11-30-04, 12:53 PM
Anyone done this yet? I might do this when I install my stereo.
Let me know which method you did.
TripleBlackCadillac
01-12-05, 04:39 PM
Where exactly is the DRL relay?
ShadowLvr400
07-27-05, 03:21 PM
Bringing this thread back from the dead. :)
ShadowLvr400
07-28-05, 06:43 PM
Ok, I went in there, and my car has everything there, EXCEPT the DRL Relay... Ugh
sonjaab
07-31-05, 01:32 AM
Also check out http://www.lightsout.org
