: How To Replace...
Faber
05-17-12, 08:00 AM
See below pic - on my driver side this vertical bar (window guide?) has the paint peeling off. Just curious if anyone knows how to replace...
92112
thebigjimsho
05-17-12, 01:24 PM
Plasti-dip!
CTSV_510
05-17-12, 02:08 PM
:yeah:
Faber
05-18-12, 08:51 AM
didn't even consider that - I'll give it a shot this weekend and hope it's a close match.
RADEoN
05-20-12, 11:08 AM
it'll be close, it wouldn't be a bad idea to go over them all.
Faber
08-28-12, 08:12 PM
Finally got around to doing this. While not perfect, the plastidip worked sufficiently enough. Only thing I should've done was sand down the rough edges from where it was peeling b/c you can still see the outline of where it peeled off. Good thing is, easy enough to redo whenever I feel like it. THanks for the idea thebigjimsho!
BEFORE
http://i1062.photobucket.com/albums/t486/mfaber1/ee97da1f.jpg
AFTER
http://i1062.photobucket.com/albums/t486/mfaber1/3e52da38.jpg
NCOGNITO
08-28-12, 11:01 PM
Although the original question wasn't answered, the top metal trim piece on my rear passenger door needs to be replaced. (The one just above the piece Faber is referring to). I think the part # is 25778959, listed as weather-stripping unless it's 25778962 which is listed as a stationary vent ($1000?). It has small dents in it, presumably from someone tapping a snow scraper on it that plasti-dip wouldn't resolve. Anyone know how to remove for replacement, which likely involves removing the piece Faber is referring to?
thebigjimsho
09-03-12, 01:00 PM
I hear many are using the Trim Brite on the window trim...
kerberos
09-04-12, 10:37 PM
Still waiting for someone to plasti-dip the whole car...
thebigjimsho
09-05-12, 06:25 PM
Been done numerous times already on V2...
