: Daytime running lights?
glitterjunkie
05-14-12, 08:28 PM
My mother has a 2007 Escalade, one of her running lights is out. I went to Pep Boys to get a new bulb, but after looking in the computer myself, then asking staff for help, there is no daytime running light listed for the Escalade. Are the called someone else? Or could someone tell me what bulb she needs?
Thanks!
the cadillac man
05-14-12, 08:51 PM
Thanks!
You are in the wrong section this one is for the 06 and older escalades but most of the time it is a standred size bulb like a 3156 or 3157.
P.s. it should be listed in the owner's Manuel.
glitterjunkie
05-14-12, 09:00 PM
ooops! thanks!
the cadillac man
05-15-12, 12:19 AM
Glad to help
felixgun
05-23-12, 06:39 AM
Actually he is in the right section... this is the 07+ section.
Thanks!
I replaced the DRL's in my headlamp assembly with LED's and the bulbs are Type 194. Hope that helps bud.
hcvone
05-23-12, 06:59 AM
The DRL bulb is a #5201
David999
03-28-15, 02:23 PM
I am very confused. For DRL and Fod upgrade to LED in 2007 Escalade, can I use 5202 LED for both, or does one require 5201 and the other 5202. It seems that bulbs list 5201/5202 suggesting they are the same..
justinesky
03-29-15, 12:10 PM
DRL is 5202 or H16. I just replaced mine with LED. Parking lights are 194's...
Tony37x
04-02-15, 10:28 AM
How easy was the LED swap? Just did it from the top by loosening a few things up?
justinesky
04-02-15, 10:01 PM
Yes. Pass side i had to remove air box and on drivers side you need to remove batt tray to loosen washer fluid bottle to move it out the way.
gatorboy112
04-03-15, 01:43 AM
Anyone know where the list of the numbers for leds for all the lights on the escalade? I have the 13' ext and want to swap it all over.
JLeosnow
04-03-15, 11:41 AM
Here is a start for you..
9005/H10-Fog
5202/H16-DRL
194/T10 Parking
-John
Esky2009
04-06-15, 11:32 AM
Make sure you get the 14V DRL due to GM changing the voltage over to 14v. Otherwise, you're going to have problems with the Drivers side DRL burning out...
sakm87
06-03-15, 10:49 PM
Does that apply to a 2007?
CoupeDTS
06-03-15, 11:14 PM
Dont get the super cheap LED either. They wont be bright, they will be a weird purple or blue instead of white and they wont last. Spend atleast 15 bucks on a pair. My daytimes are bright white and has the look of most of the new cars driving around with the fancy white LED strip drl's. I swapped over every bulb inside and out to LED. For front turn lights u need to add a resistor.
MLTucker
09-05-15, 12:57 PM
We changed our 2007 Cadillac Escalade daytime running lights with part #5201 Sylvania Basic from Autozone.
