View Full Version : Revshift Trans Mount Inserts
05-13-12, 03:11 PM
Don't spend hundreds of dollars on a questionable aftermarket trans mount when you can convert your oem mount to a high performance mount with this insert for a fraction of the cost.
The trans mount insert is made from high quality polyurethane with an 80A hardness. It was molded to perfectly match the inside of a brand new OEM transmission mount. It will significantly stiffen the OEM trans mount creating less slop in the driveline. It will also prevent sagging and drastically extending the life of the OEM mount.
05-14-12, 08:02 AM
Interesting. How is it installed?
05-14-12, 10:31 AM
It presses in. You can use a bench vise, a big C-clamp, someone with very strong hands, or an actual press. Its a tight fit but its pretty easy to install.
