: Let the mods / tweaks begin...
Ludacrisvp
05-13-12, 08:18 AM
Finished my first interior modification, well after having the car tinted that is (30% sides and rear, 50% windshield)...
Also finished exterior modification (not pictured) removal of the GM badges on fenders.
Also finished exterior modification, 6 high beams, (fogs remain on during high-beam) since the IntelliBeam is always going from High to Lows since I drive at night everyday for work it does a lot of flashing of my fog lamps.
So a small modification in the relay center allows Fogs to remain on whenever the high beams are on.
On order ... STS Lockpick, RHO plate mount for front plate (says CTS-V only but I'm gonna risk it based on measurements in a thread in the V series thread for this mount)
Wrapped in matte black raven vinyl. The sun glare from the 'brushed aluminum' finish was irritating.
http://farm9.staticflickr.com/8159/7180968512_07e6ab7454_b.jpg
Did the bottom of the wheel too, not around the steering wheel buttons as I am not sure how to remove them yet.
I did the vinyl wrapping of the wheel portion while it was still on the wheel.
http://farm6.staticflickr.com/5331/7180967948_6840feeb9a_z.jpg
Lows / fogs --- Camera doesnt really capture the look the best but it gives you an idea...
http://farm6.staticflickr.com/5461/7180967698_c22f60e1cb_c.jpg
Highs / Lows / fogs --- Camera doesnt really capture the look the best but it gives you an idea...
http://farm9.staticflickr.com/8006/7180967454_9641fb3c13_c.jpg
1BadCadSTS
05-13-12, 09:55 AM
Looks good. How did you run the wire for the fogs? Just jump the relay?
Charles Warren
05-13-12, 11:00 AM
Gm tech 2 has a option you override to make the fogs stay on with high beam. And to the op that looks good.
Ludacrisvp
05-13-12, 11:10 AM
Thanks.
Jumped the relay in the relay center to the parking lights since the actual relay for the high beams doesn't seem to actually do anything. My highs work with and without the high beam relay installed.
I was unaware of the tech 2 offering that feature. I may have to have that enabled and turn on the afterblow feature of the hvac system and I'm sure there is probably something else that the tech2 can do.
Ludacrisvp
05-14-12, 07:28 AM
One more thing regarding the TechII, its times like these where I really wonder if it would be worth it to spend the $1k on buying a TechII for myself / family use.
I say this as all the family's cars are GM, not to mention the cars we no longer have were GM too.
Mine:
2008 STS AWD N* 4.6L
2001 Monte Carlo SS 3.8L
Parents:
2004 SRX AWD N* 4.6L
2006 SRX AWD N* 4.6L
1999 GMC Sierra 2500 Ext 6.0L vortec
Brother:
2007 Impala SS 5.3L
2005 GMC Envoy long wheelbase
Sister:
2005 Buick Rendezvous 3.4L
So I noticed in the sunlight on the drive home from work yesterday that the vinyl I used on the dash and steering wheel has the same sparkle / metallic look to it that the factory plastic does for the grey/black plastic of the hvac / nav controls.
This look makes it seem really like it was an OEM option to have either the brushed aluminium or black for the trim pieces.
Having it done this way also makes the fake chrome of the vents POP out at you like 'hey did you see this little chrome strip? No? WELL HERE IT IS!!!'
I did have to peel off the steering wheel one as once it sat in the sun it appears it ended up peeling up on the bottom edge.
Looks like I will have to determine how to remove that part from the wheel before I can do it again so that I can wrap the part like I was able to do for the dash piece.
Does anyone know how to remove the piece from the steering wheel that is below the air bag?
Do I need to pull the bag and the wheel?
1BadCadSTS
05-14-12, 02:49 PM
Got an instruction on this?
EChas3
05-14-12, 10:16 PM
Tech II's should be coming down in price on eBay & the like. Are they not only used on older cars?
Ludacrisvp
05-20-12, 06:10 AM
Well I installed the nu-STS which is the new STS lockpick made by PAC, this one uses the SRCE button being held down for 4 seconds to initiate the switch to unlocked mode rather than the mute button method.
Works well so far, here are some pics and a video of the 'interface'.
http://farm8.staticflickr.com/7237/7228399240_b501250b07_z.jpg
http://farm9.staticflickr.com/8013/7228398790_0ee5e5b8b3_z.jpg
http://farm8.staticflickr.com/7076/7228399750_36e090824e_z.jpg
Here is a quick YouTube video showing the enable / disable / functionality of the unit.
Note my car is not running in ON mode at this point for demo, as I was in the garage at the time and didn't want the car running.
http://www.youtube.com/v/J4m1ojjdTco
Here is the 2009+ Cadillac CTS-V 'only' RHO plate mount. I contacted the company to see if the plate mount would work on the 08+ STS, they said NO it is only compatible with the CTS-V.
I had a member measure theirs and based on that info, I ordered one anyways. Works just fine! If anything it could be 1/2" shorter shaft but either-way its better than the plastic mount option.
No flash
http://farm8.staticflickr.com/7220/7228672722_7306802903_b.jpg
With Flash
http://farm8.staticflickr.com/7229/7228673742_a38e1ef38d_b.jpg
jgoble48
05-28-12, 09:01 AM
Does anyone know if the PAC NU-STS lock pick voids the warranty on the nav/ radio components? Thanks...
1BadCadSTS
05-28-12, 09:55 AM
Remove it before going in for any Nav replacement serivce. Not that hard.
Ludacrisvp
05-28-12, 11:44 AM
Real simple one trim piece held in by 6 friction clips and the Nav held in with 4 bolts. Then a few plugs and done. Not permanent nor leaves any evidence behind.
jgoble48
05-28-12, 11:45 PM
Thanks guys. That's what I'll do.
cadillacmike68
05-29-12, 03:13 PM
I assume a dealer service procedure unless one already owns a Tech 2, correct?
What else can the Tech 2 "fix"???
eatyoursandwich
05-29-12, 04:42 PM
Unfortunately, this depends on the competency of the tech at the dealer. Some know just about every "trick" Tech II has to offer, others just know what's in the manual. I guess my dealer is really 'by the book' because they won't code the fogs to stay on with high beams for me even though I offered to pay an hours worth of labor for a job that takes 5 minutes to do.
EChas3
05-31-12, 10:25 PM
Aftermarket devices do not void warranties. There's a federal law to that effect. I forget the sponsors names (as that is the usual way to refer to such legislation.)
However, members' posts are correct. If you need service, just remove the Lockpick. Once you've done it once or twice, removing a Lockpick is a 15 minute task.
eatyoursandwich
06-01-12, 10:21 AM
Magnuson-Moss Act.
Basically, in order for the dealer NOT to cover something under warranty due to an aftermarket part, the dealer has to prove it was the aftermarket part that caused the issue. Simply just being there does not void a warranty.
tomm
06-03-12, 09:38 PM
No warranty issues and its a simple plug and play connection.
Charles Warren
06-06-12, 07:14 AM
im just now seeing this but guys i got the info form this thread
http://www.cadillacforums.com/forums/cadillac-forum/t-187488.html
