: HID fogs
JoeS823
05-09-12, 01:41 PM
Just bought an HID kit for the H11 fog light bulbs, anyone have any tips or tricks to installing these before I dive right in? Does the bumper need to come off?
LFTW8S
05-09-12, 04:05 PM
Easy install. No need to pull the bumper. Drop the panel behind the fog and a lil access from the wheel well. Good luck!
Bigron
05-09-12, 04:38 PM
Take the wheel off, take the wheel liner off. Nice "shelf" above the fog housing where you can two side tape the ballast above.
I took some pictures, let me see if I can find them tonight.
JoeS823
05-09-12, 06:11 PM
Pictures would be awesome, thanks.
Stillborn
05-09-12, 06:27 PM
what a coincidence, i have a spare set of h11's 8k (ddm) from my navigator fogs. and i thought they'd just collect dust on the shelf. =] subscribed.
JoeS823
05-09-12, 06:32 PM
Haha I just picked up a kit with 6k bulbs I'll probably do the install tomorrow after work.
smackdownCTSV
05-09-12, 06:35 PM
6K and 8K are pretty blue.
JoeS823
05-09-12, 06:36 PM
What's the stock headlight bulbs output?
Stillborn
05-09-12, 06:46 PM
i would say its in the 4k spectrum.(stock bulbs) i think d3 sells a full kit. just find out what bulb size and order them from ddm too. i'm sure it's a lot cheaper than d3's kit.
JoeS823
05-09-12, 06:48 PM
I figured it was high 4s, 6k was the smallest one he had, I can always change out the bulb if I decide it's too blue, I had 8500k on the Acura TL I owned before my V and those were pretty blue, I think 6k will look alright.
Stillborn
05-09-12, 06:58 PM
i like the blue vs the pale white spectrum of american stock bulb vehicles. the blue spectrum looks much more high end.(euro) the only draw back is the piping lights on the sides. i dont think there is a conversion for those yet.
smackdownCTSV
05-09-12, 07:43 PM
8K is ricer blue, and I wouldn't be surprised if it puts out less lumens than the halogens in the fogs now.
Vwagon2012
05-09-12, 08:02 PM
Got the kit from D3 on ebay they are the same color as headlights. Look right together
JoeS823
05-09-12, 08:03 PM
What's the output on the d3 kit?
jrcmlc
05-09-12, 09:00 PM
The 8k certainly will yield less usable light than the 6k and then than the 5k...and the 8k from ddm is not BLUE, but it's a little ricey, although if you do the 55w ballasts it tends to whiten it a bit for whatever reason.
JC
Stillborn
05-09-12, 11:13 PM
this is ddm 8k both upper and fogs...pretty rice huh?
91573
smackdownCTSV
05-09-12, 11:34 PM
Blue is rice, white is nice.
JoeS823
05-09-12, 11:58 PM
I'm hoping the 6k isn't too blue.
LFTW8S
05-10-12, 02:14 AM
55w 5k was a perfect match for me.
JoeS823
05-10-12, 09:18 AM
My ballast is a 35w
smackdownCTSV
05-10-12, 09:45 AM
4300K or 5000K is best, 6000K will have a slight blue hue and look even blue-er next to the 4300K stockers.
JoeS823
05-10-12, 10:12 AM
Hopefully it doesn't look too blue to the point where it will look stupid
smackdownCTSV
05-10-12, 10:13 AM
I guess you'll find out. HID bulbs are cheap enough if you decide to go with a 5000K.
BLEWBYUWIT6.2
05-10-12, 10:25 AM
just did my top and bottom 2 weeks ago....but i bought the 10k... not bright enough...going to buy the 5k this week...thanks to the previous owner there are no splash sheilds under the car ...so it was really just 4 bolts and about 5 or 6 of the plastic push pins....ballast are neatly tucked away behind the bumper support.....good luck with yours
JoeS823
05-10-12, 11:34 AM
Is there room if you go from up under the bumper as opposed to taking the tire and fender liner out?
LFTW8S
05-10-12, 02:38 PM
Yes. No need to pull the wheel
JoeS823
05-10-12, 03:06 PM
Cool sounds easy enough
Bigron
05-10-12, 03:46 PM
Blew the tire off my daily driver last night changed my plans.
I went through the wheel well so I didn't have to get under the car to get to the fogs. Either way you are popping a bunch of those annyoing clips.
Plus I got a chance to paint the hubs of the rotors while the wheel was off.
I went with 5,000k and 55W. 55w washout the color a little. I would have went 4,500k for 35w if I was trying to match the OEM headlights.
JoeS823
05-10-12, 03:54 PM
My tire blew out on my daily too last night haha, I hate gm push clips but I don't have an impact gun at my house so I'll probably end up going up through the bumper and taking the splash shield off the bottom.
Junkie414
05-10-12, 08:45 PM
Anybody have the link to a D3 or matching HID setup for the fog lights? I suck at the internet.
Havasusteve
05-10-12, 11:44 PM
They have a few different versions available. I purchased the 4300 kit from their distribution center and they match EXACTLY IMHO the OEM headlights just the way it should have come from the factory. Jacked the front of the car up, popped the access panels in front of the wheel wells; double back taped the ballasts to the inner bumper liner. 2 hours max for a ding-dong like me.
Regards
Steve
PS I have ZERO affiliation with D3 whatsoever...They jusy happen to be local :)
JoeS823
05-13-12, 10:58 AM
Put them in yesterday, they look SO much better than the stock halogen fogs, gm should've put HID fogs in the v in my opinion
LV_V
05-13-12, 11:22 AM
Has anyone wired these to come on with the main headlights? Any reason not to?
Stillborn
05-13-12, 02:01 PM
no need, you can turn on the fogs at will with a forward roll on the light stem. if anything, people want to use the side light bars at driving lights.and i agree, they look great, the only issue is they look good only when you press your unlock fob control and they're 5x brighter than when the car is running. i would love to see someone forge this route and make a plug and play relay.
joe, you going to H.D. today? i'll be up @ 5ish. i wanna see those fogs... =]
JoeS823
05-13-12, 02:32 PM
I'm not 100 percent sure if I'm going down there today, got some family over but it sure is nice out, I'm gonna try to get there at some point.
LV_V
05-13-12, 04:44 PM
If I went with the DDM D1S replacement bulbs for the headlights and their 35w H11 kit for the fogs am I going to be good?
JoeS823
05-13-12, 08:14 PM
Whats the output you ordered? 4300k, 6000k?
JoeS823
05-14-12, 12:51 AM
Here's a picture of the difference between the stock (passenger side) to the 6k hid (driver side)
http://i258.photobucket.com/albums/hh249/joe2252001/c52d17c6.jpg
thebigjimsho
05-16-12, 12:01 PM
If you got the Hoens, they are not HID but match stock color.
JoeS823
05-16-12, 01:17 PM
Has anyone done hid DRLs?
