View Full Version : Clutch bleeding difficulties- lost all pressure and stuck
Overd0s3
05-05-12, 07:10 PM
I always did the turkey baster method of changing my clutch fluid but I decided to tackle the task of bleeding the whole thing.
I found the valve and followed the pattern from the FAQ, open, clutch down, close, clutch up.
I got maybe 3 rounds in until it stopped flowing and now there is no clutch pressure.
Maybe like 50ml if that got out and I continued to do the pattern above with a friend about 250 times and no luck. The reservoir is full and I'm out of ideas. I have absolutely zero pressure.
Any ideas?
Note that no fluid is coming out of the valve, maybe tiny spirts here and there but something has to be up
darkman
05-05-12, 07:13 PM
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/248383-problem-bleeding-clutch.html#post2812657
Look at the above. I think you may be omitting a step where the valve is opened with the pedal depressed to allow air to escape.
Overd0s3
05-05-12, 07:23 PM
I followed those exact steps and Im stuck with no pressure, the bad fluid is still in and won't come out. I even tried to suck it out with a pump and it won't come out
in any case what do I do now?
darkman
05-05-12, 07:29 PM
I think I would open the bleeder and let it gravity bleed for a few minutes, and then try again.
Here is a thread with some variations on the bleeding procedure.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/253086-serious-trouble-bleeding-clutch.html
Overd0s3
05-05-12, 07:40 PM
Ok Im gonna open it and let it sit for a few hours and see what happens
darkman
05-05-12, 07:41 PM
I think all you are up against is some air in the line.
Overd0s3
05-05-12, 08:01 PM
Just doesn't make any sense how that air got in. should the cap to the res be opened or closed while its gravity bleeding?
darkman
05-05-12, 08:11 PM
Open for gravity bleeding. You did try opening the valve while holding the clutch pedal in the depressed position, right? If so, did anything come out - if there is air in the line it should come out then.
Overd0s3
05-05-12, 08:21 PM
nothing came out, just air. how much fluid does the whole system have?
darkman
05-05-12, 08:29 PM
The fluid capacity is not specified in the book, my guess is no more than 8 ounces.
Looking over some of the other threads and posts - some report being able to restore some pedal by simply pumping the pedal with the system closed (bleeder closed, reservoir lid on.).
RVO27
05-05-12, 09:15 PM
Check to make sure the diaphragm for the clutch reservoir cap isn't sitting in the reservoir. The first time I bled my clutch I didn't notice that the diaphragm had not come off with the cap and I was putting the fluid on top of it.
rand49er
05-05-12, 10:02 PM
Have never done this myself, though I've paid to have it done.
Now I know why.
Overd0s3
05-05-12, 10:20 PM
thanks everyone for the quick responses I have it back up running I was just an idiot and didnt keep the res full
once I figured it out it took no more than 15 mins. How much did you pay to get it done?
