: 2007 EXT suspension
05-02-12, 08:25 PM
Compressor has been noisy and does not work now. Also compressor had been running for a while and not shutting off. Removed compressor and put 12V to the red and black leads to the motor - does not work. Tested the power leads at the harness plug feeding compressor and no 12V.
Compressor relay would feed to the compressor ? If so is the relay the one by fuse panel ? (gray colour- saying Omron 12177235)
Would a ceased compressor do in the realy?
Is there a leveling valve?
Have checked fuses and they are good
Any help would be appreciated!
