View Full Version : 02 Escalade-VERY slow window
arejaye5000
04-25-12, 12:56 PM
I have an 02 Escalade, and my passenger window has been getting slower and slower going up/down. Any suggestions as to what's going on? Need to be cleaned or is the regulator going out?
Thanks!
78seville455
04-30-12, 04:45 PM
I would say clean and lube all the regulator parts just in case it's drying out. If the problem persists after that I would check the voltage getting to the motor, and also check the amperage draw. It may not be getting proper voltage, due to a bad switch or relay. Or the motor may be going bad..... Which would cause high amp draw.
