: Just add
Blackcady07
04-12-12, 07:51 PM
K&n intake system and the throttle bottle spacer by air raid is the best thing you could do very happy
48Dodge
04-12-12, 09:06 PM
You'd be the first person I'd heard about actually getting gains from a TB spacer.
Sent from my Xoom using Tapatalk 2
hcvone
04-13-12, 06:24 AM
The air intake I can see, but as said I have never seen any dyno gains with a t-body spacer, glad you're happy :)
K9Caddy
04-13-12, 07:52 AM
Throttle body spacers serve no purpose on our engines. They use to add a few ponies in the older fuel throttle bodies, that were similar to the older carb style. They would act as a heat spacer between the intake manifold.
jeray
04-13-12, 03:00 PM
I agree, I just added the Volant Cold Air and Ram Air intake along with the throttle body spacer. Had the tb on before the intake came in, not a big difference.
hcvone
04-13-12, 03:04 PM
You are correct, raising the t-body of the old electronic carb fuel injection made a difference because you were were allowing the gas a longer mix time, but with port fuel injection there are no gains because only air is being sucked thru the t-body today
