View Full Version : 2007 Escalade ESV Shifting hard from 2-3 . Then P2714 code P0700 code & a few other
Rustico
04-09-12, 06:42 AM
Under moderate to heavy throttle at around 35mph the Transmission revs up to 5000 rpm but doesn't shift to the higher gear So I have to let off the throttle THEN it shifts. Then the check engine light comes on and gives Code p2714 and p0700
Cadillac Cust Svc
04-09-12, 12:20 PM
Welcome, Rustico! I'm very sorry to hear that you've been experiencing this with your Escalade so shortly after your purchase. I would recommend visiting your dealership for service, but if you're more of a fan of the Do-It-Yourself approach, I'm sure you'll find the community members extremely helpful here! If you would like me to investigate any concerns further for you or locate a dealership for you, please feel free to email me anytime at Katie_Lucille@gmexpert.com.
Best,
Katie
Cadillac Customer Service
cadmanchris
04-09-12, 02:39 PM
Sounds like a problem in the lower valve body. The TCM is bolted to the valve body. If memory serves me right, the cleaning procedure is no longer recommended.
Ghost Deany
04-09-12, 10:27 PM
Sounds like the crappy 2-3 shift. Theres a TSB for that i believe. I had it on mine too, dealer replaced sealing rings with a new design, now it all shifts smooth as butter
Rustico
04-10-12, 09:56 AM
If it is the new design 2 piece o ring seal that is needed does anyone know how much it should cost to replace? At the dealer or at an independent shop. I am outside warranty.
Ghost Deany
04-10-12, 10:23 AM
outside power train warranty?
Rustico
04-10-12, 10:55 AM
yes I am outside powertrain warranty so I have to cover the costs myself
Jmunoz
07-21-14, 01:29 PM
I have the same codes what Did you fix?
MsTina73
01-26-15, 05:38 PM
I got the same codes today, any idea what has to be fixed and how expensive?
allblackescalade08
08-12-15, 08:58 AM
My 2008 escalade is slipping from 2-3 when cold. Is this the same problem? How much to fix?
DarkCharisma
08-20-15, 11:52 AM
Called the Cadillac dealer here in Tampa to apply the TSB for the 2-3 flare, was quoted $2200.
