View Full Version : Which PCM used for 2006 STS 4.6L rearwheel ?
Team ZR-1
03-25-12, 05:42 PM
Any know which PCM is used for a 2006 STS with NA 4.6L (code A)engine and rear wheel drive,
is it a E67 PCM ?
Thanks
pcmcalibrators
03-26-12, 07:54 AM
We have 1 in stock, but it's not an E67
2006 4.4L STS-V uses an E67
Part Number: 12576523
CADILLAC 2004-2006
SRX 2004-2006
STS 2005-2006
XLR 2004-2006
Team ZR-1
03-26-12, 02:04 PM
This STS is a 2006 with 4.6L N/A, rear wheel drive and I was told depending on which engine, if having boost or front or rear wheel drive had different PCMs but which PCM does the NA 4.6L rear wheel use ?
Thanks
pcmcalibrators
03-27-12, 07:26 AM
This is the E22 ECM used in 2004 to 2006 RWD Northstar's except the 2006 STS-V 4.4L
http://i1106.photobucket.com/albums/h361/PCMCalibrator/PCM%20and%20ECM%20Types/E22%202004%20to%202006%20RWD%20Northstar/2004N12588944Connectorside.jpg
This is the P07 PCM used in the 2004 & 2005 FWD Northstar ------ Note it is the same picture -- I will have N0dih update it
http://i1106.photobucket.com/albums/h361/PCMCalibrator/PCM%20and%20ECM%20Types/P07%202004%20and%202005%20FWD%20Northstars/2004N12588944Connectorside.jpg
This is the 2 side by side
http://i1106.photobucket.com/albums/h361/PCMCalibrator/PCM%20and%20ECM%20Types/P07%202004%20and%202005%20FWD%20Northstars/2004compareECMPCM.jpg
---------- FWD ------------------------------------------------------------- RWD
http://i1106.photobucket.com/albums/h361/PCMCalibrator/PCM%20and%20ECM%20Types/P07%202004%20and%202005%20FWD%20Northstars/2004PCMSECM-1.jpg
This is the E67 used in 2006+ FWD Northstar, the 2006 STS-V, and 2007+ RWD Northstar's
http://i1106.photobucket.com/albums/h361/PCMCalibrator/PCM%20and%20ECM%20Types/E67/E67ConnectorSide2.jpg
Team ZR-1
03-27-12, 05:58 PM
Damn then not good news as it looks like this STS would be using a E22 PCM since it is rear wheel and not a E67 :(
That leaves out using Tunercat or LS2edit for tuning, so what tuning tool would work ?
Thanks
pcmcalibrators
03-28-12, 07:24 AM
Thanks
John says the E22 uses a non AVT supported CPU
