View Full Version : 2007 Escalsde Windshield Wiper Arms - Replacment Part Numbers
Aerocoupe
03-24-12, 12:32 PM
I was debating on repainting the arms or just replacing them and decided to just replace them as painting them would take some time and I am just jammed up with the honey-do list. I went to the local Caddy dealer and the guy at the parts counter was super nice and they actually had them in stock (Houston, TX so its a big market). They took about fifteen minutes to install and required a small flat tip screw driver to pop off the cap at the base of the arm and a 15mm wrench to remove the retaining nut. You have to have something to pop the arm loose off the stud and I used a trim panel tool. The part numbers are as follows if you want to search them out on the net as there is a substancial cost savings:
GM #15916552
GM #25872299
http://www.gmpartsdirect.com/results.cfm
Hope it helps someone down the road.
Darren
dan48
03-19-14, 05:24 PM
I haven't installed them yet but mine arrived today. Thanks for posting the info!
