View Full Version : Voice commands
Kdizel
03-23-12, 08:37 PM
Does anybody use the voice commands in your escalade??? havent got mine to work yet!!!!Gave up cause it never recognized my voice.....what do you say to the darn thing?? How does it work?? Read manual but..???? Maybe you can clarify how this is supposed to work!!
I know u press the button and hold and it ask for command but it never does the command!!
Kdizel
03-25-12, 05:03 PM
Nobody......
Nice Ride
03-25-12, 07:49 PM
Nobody......
If you have on star. Hold button down, when it prompts you, say: dial 5165551212. It will repeat the number and display it on the dash... Your owners manual should have a list of all the commands...
Kdizel
03-26-12, 09:47 AM
R u talkin bout the onstar button or the button on the steering wheel cause I can make it dial numbers through onstar but it never understands the command when I press the command/mute button on the wheel
roadog1aj
03-26-12, 12:13 PM
I believe there are two different systems at work with commands.....On Star commands, and internal voice commands. If you are referring to the internal voice commands, I think you need to press and hold the "SRCE" button until you hear a beep, then you can use other commands such as Navigation, Radio, etc. I made a little "Cheat Sheet", and laminated it, to use because I can't remember what to say, or how to say it. I have copied the commands I have used below. Maybe this can help you?
Be sure Nav/Radio System is On: It can be on any of the available options: Radio, Navigation, Sat Radio, etc
Voice Commands (Press and hold: “SRCE” button on steering wheel until you hear a beep, then state one of the following commands:
“Navigation Go To” (Voice Tag) example: Lisa, Dad, Home, etc.
“Navigation Help” opens system to assist with navigation commands
“Voice Help” opens list of Help commands that can be used
Radio Commands:
“Radio AM” chooses AM band
“Radio FM” chooses FM band
“Radio (frequency) AM” chooses frequency for AM (example: 1220, 1240, etc)
“Radio (frequency) FM” chooses frequency for FM (example: 97.4, 104.7, etc)
“Radio Help” opens system to assist with radio commands
CD, DVD, MP3 Commands:
“CD”, “DVD”, “Disc” selects a CD, DVD, or Disc that is currently loaded
“CD”, “DVD”, “Disc” “Track” (one, two, three, etc) system selects that specific track
“CD”, “DVD”, “Disc” “select next folder”, or “select previous folder” selects next or previous folder if one is on the disc
“CD Help”, “DVD Help”, “Disc Help” opens system to assist with CD and DVD commands
“Aux”, or “Auxiliary” selects the Auxiliary device when one is connected
Kdizel
03-27-12, 01:35 PM
This is so helpful to me....thanks so much!!!
PeteKT
03-29-12, 02:40 PM
Sweet i NEVER knew my truck had this, just went and tried it but i have a seperate button next to the SRCE button for it.
Found this online
The navigation system's voice recognition allows for hands-free operation of the navigation system, audio system, and OnStar® features. The DVD map disc must be installed in the navigation system for voice recognition to work. See "Installing the DVD Map Disc" under Maps . Voice recognition can be used when the ignition is on or when Retained Accessory Power (RAP) is active. See "Retained Accessory Power (RAP)" in the Index of your vehicle's owner manual and for more information.
To use voice recognition, do the following:
Push and hold the SRCE (source) steering wheel control until you hear a beep. The audio system, if on, will mute.
Clearly state one of the commands listed on the following pages.
Helpful Hints for Stating Commands
• When a multiple command is available, choose the command that best works for you.
• Words that are in brackets are optional. For example, for the command Radio [band] [select] FM, stating Radio FM or Radio select FM are both valid commands.
• When the system recognizes the command the system will:
- either perform the function
- ask you to confirm your choice by clearly stating "yes or no"
- issue an error message such as "System does not recognize this command" or direct you to "Please start speaking after the beep"
• If the system is not yet ready, the system may state "System is checking the disc. Please wait.".
• To cancel a command or if the system response does not match your verbal command, press and hold the talk symbol button. The system will reply, "System will cancel the voice recognition".
• If you experience difficulty with the system recognizing a command, try saying it more softly, and wait for a few seconds after the beep, or you may just try saying it again.
• Background noise may cause voice commands to be misunderstood, including airflow noise from wind.
• To use the voice recognition system, the map DVD must be loaded.
This system is able to recognize commands in three different languages. The system will only recognize commands based on the language selected from the Driver Information Center (DIC). See "Driver Information Center, DIC Vehicle Personalization" in the Index of your vehicles owner manual.
Voice Recognition Commands
The following list shows all of the voice commands available for the navigation system with a brief description of each. The commands are listed with the optional words in brackets. To use the voice commands, refer to the instructions listed previously.
Voice Tag Commands
The following are voice tag commands you can access by clearly stating the commands exactly as they are written. You may have up to 40 voice tag entries for destinations.
Navigation go to [destination] (voice tag), navigation select [destination] (voice tag): These commands instruct the system to select a destination saved under the voice tag you have stored. When a destination is requested using a voice tag, the system will state, "Press or say cancel if not correct". To cancel this voice tag destination, using voice recognition, push and hold the (talk) steering wheel control until you hear a beep, then say "cancel". If you are not currently driving on a route, the system will automatically create the voice tag destination as the final destination. If you are currently driving on a route, the system will automatically create the voice tag destination as a waypoint. Up to three waypoints can be created.
Storing Voice Tags
From the address book entry information page, press the Add Voice tag screen button. The system will respond "Name Please?".
Navigation Help
Navigation Help: This command instructs the system to assist with navigation commands.
Display Commands
Use the following display commands to set the display mode.
Display [set] day [mode]: Use this command to set the display to daytime mode.
Display [set] night [mode]: Use this command to set the display to night mode.
Display [set] auto [mode]: Use this command to set the display to automatic mode. The system will change between day and night mode automatically.
System help: This command instructs the system to assist with display commands.
Radio Commands
The following are radio commands you can access by clearly stating the commands exactly as they are written. The commands are only available when you are in one of the following audio modes, AM, FM, or XM™ (if equipped).
Radio: This command instructs the system to turn the audio system on.
Radio [band] [select] AM, radio [band] [select] FM, radio [band] [select] XM, radio [band] [select] satellite: These commands instruct the system to go to either the AM, FM, or XM (if equipped).
Radio [select] (frequency) AM, radio [select] (frequency) FM: These commands instruct the system to go to a specific frequency on either AM or FM.
Radio [select] (channel) XM, radio [select] (channel) satellite: These commands instruct the system to go to a specific channel on the XM™ band (if equipped). The channel must be a valid channel or the system will keep the radio at the current station setting. The system will pause while searching for the channel.
Radio help: This command instructs the system to assist with radio commands.
CD Commands
The following are CD, MP3, and DVD commands that can be accessed by clearly stating the commands exactly as they are written.
CD, DVD, Disc: Use this command to select a CD, DVD, or disc that is currently loaded.
CD, DVD, Disc, [select] track (one, two, three, etc.): This command instructs the system to select a specific track number.
CD, DVD, Disc select next folder: Use this command to select the next folder on the MP3 or audio DVD.
CD, DVD, Disc select previous folder: Use this command to select the previous folder on the MP3 or audio DVD.
CD help, DVD help, Disc help: This command instructs the system to assist with CD and DVD commands.
Auxiliary Commands
The following auxiliary commands can be accessed by clearly stating the commands exactly as they are written. The commands are available when the auxiliary source is available.
Aux, Auxiliary: Use this command to select the auxiliary device, when a device is connected.
OnStar® Command
OnStar: This command instructs the system to connect to OnStar®. You will enter the OnStar® voice recognition system. Refer to your OnStar® manual for more information.
Voice Help
Voice help: This command will provide a description of help commands that are available to use.
chakde
03-29-12, 06:13 PM
In addition to the above there is also the "Bluetooth" command which I use to pair or change phone etc.
Cadillac Cust Svc
03-30-12, 03:56 PM
Hi Kdizel,
I see you've received wonderful feedback already, and I'm just catching up on this thread now. Are your voice command issues resolved? If you still have questions, I'm happy to elaborate for you. Private message me anytime!
Katie
Cadillac Customer Service
Kdizel
03-31-12, 01:41 AM
Yes.....this is good.....thank u katie.....great info......good forum.....thanks everyone for help!!!!
Jgun
04-01-17, 05:11 PM
I have a heated steering wheel on my 2012 SRX which replaces the SRCE button. If I use the voice access for the telephone buttom, it does not allow be to set a navigation direction unless I go through Onstar. Is there any workaround for this situation? Thanks
AZKlaus
04-02-17, 10:12 AM
Love that we have voice controlled navigation but no Bluetooth audio even though Bluetooth 2.0 which had reliable A2DP support (bluetooth stereo audio) came out in 2004... They waited until 2015 to put that in, never made sense to me.
