Looking at the OBD2 reader I've got hooked up, shows a peak airflow of 236 g/s air from the MAF, working out to about ~80.4% volumetric efficiency at peak RPM (6300). Anyone? Induction system in good shape, reasonable shape, or needs a cleaning? (I've no issues or complaints, I'm just curious...)
The standard automotive airflow calculation uses a VE of 80% - most wonderful for a stock engine.
I'm not going to post it all - Google "automobile engine airflow calculations" and do the math yourself.
3 years ago I screwed around with a mechanically modified MAF - JET Performance - and got exactly nothing worthwhile. This was done over two 821 mile round trips from MD to FL and I actually lost a half mpg, set mixture codes, and introduced a low speed/off idle stumble.
So..........In answer to your opine, your engine and intake system is just fine..............but go ahead and work out the formulae - you'll convince yourself that the MAF/throttlebody modification idea is pretty useless on these engines: they already have a cold air intake tract and panel filter which flows more air than a 279 c.i. engine can handle as-is.
Huh? I'm not interested in modifying it, but it could perhaps be an early indicator of exhaust cam wear for the pre-2000 engines. The only way to get more suck (without a blower) is to get a tuned (variable length) intake along with finding space for a bigger crossover pipe (there is no space), and that's not happening
Your engine already has a tuned intake manifold with 8 variable sized individual intake runners coming off the distribution log. Everything before the center lower distribution log is designed for maximum cold air flow.
.........not saying you're looking at modifications - just that a few of us have been there, and there isn't a gain to be had from fooling with the intake. You would have to have some pretty severe intake manifold sludge buildup before there would be ANY performance losses there - but a clean air filter and throttlebody is of prime importance.
Oops! I did my calculation wrong. It's about 80.4% for 236g/s - displacement is 0.0045648 m^3 and max rpm 6300 not 6000
Variable as in changing length, the runners help but to get everything possible the size needs to change...
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
