: E-Cut out Question
03-13-12, 06:18 AM
Where did you guys tap your ground and power when using exhaust cut outs?
I have TVs tapped into the rear cig lighter, so don't want to do that. I figured I'd be running the switch up to near the shifter... so wanted to know and just get general ideas on where everyone tapped their power from.
I'll be running mine post headers / pre res with a cat delete. Thanks.
03-14-12, 08:45 AM
I put my switch over by the lumbar button on the side of the drivers seat and tapped into the power for the seat. Works nice I think. Other guys on here have done the same thing I have. It's a good set up.
03-14-12, 09:53 AM
Ok cool. I may just do that. Thanks for the idea. I didn't want to wire into the spot I had the TVs set, so that works perfectly
03-14-12, 10:36 AM
I did the same last year. Put it right in front of the lumbar control.
Ny's Caddy
03-14-12, 02:18 PM
Hahaha ^^^^ Me too Same exact spot..
03-14-12, 05:05 PM
Where did you guys bring the wires into the car?
Ny's Caddy
03-14-12, 05:29 PM
Drilled a hole in side of the spare tire well
03-14-12, 06:32 PM
There is a wire harness that enters at the driver side rear tire well. I just pushed it though the same grommet. I did have to extend the wires a little bit. I have my cutouts mounted in front of the mufflers, though. You can bring the wires through a grommet at the firewall.
