: ext rear window/Midgate removal?
03-11-12, 01:00 PM
I was removing the midgate to install a midgate with a built in subbox. I removed the rear mirro also and noteced the support where the midgate latches on to came off. I thought I broke it. Then saw it also has latches to attach and remove but how do I do this? It seams as if the mirror is off when you fold down the midgate the whole piece comes down is this sound right. Or is there an othet latch or is mine broken
03-11-12, 03:59 PM
i have no idea what your talking about but if you explain it better I can probably help you. What mirror is back there? What are you trying to do?
03-11-12, 08:00 PM
I think what you mean is, if you twist one way the whole midgate opens, if you twist the other way a portion of the midgate opens so that you can still keep long things in your box while the cover panels are on.
Is this what you mean?
03-11-12, 11:40 PM
This part. I didnt know It allso came off. So I twist the handle the other way in order to bring this part down also and the rear window must be offright
