View Full Version : Where are Crank Position Sensors on 2000 Deville
Joe L
11-16-04, 09:17 PM
Can anyone tell me the location of the two crank position sensors on a 2000 Deville????? Amy good links to a diagram??
elwesso
11-16-04, 09:20 PM
They will be on the side of the egnine where the pulleys and belts are.. SHould be faily obvious.....
mastertech
11-18-04, 03:03 PM
Not sure what engine elwesso is talking about..... your crank sensors are on the left or front side of the engine just to the right of the oil filter. If you remove the lower deflector, you can see them one on top of the other. They are held in by 10mm bolts, and you will need a long extension with a swivel to get them out. Very easy job, I can throw a pair in and program the crank variation learn in about 15 minutes.
