View Full Version : Blown driver side CV boot :(
Noriega7
03-04-12, 07:32 PM
Gettin a TPMS sensor replaced yesterday and pulled the wheel off only to find grease all over the inside of the wheel and control arm. Worth replacing the whole shaft or just go for a boot through gm?
darkman
03-04-12, 08:29 PM
Rock Auto sells them $7.85. Pulling the axle to replace it is no joy though. (Maybe a good time to get a Gforce axle or two if do not already have them.)
rand49er
03-04-12, 09:45 PM
^^^ Yeah that.
My inner CV boot on the passenger side was spraying grease when I put my DSS/Hendrix axles in. A pricey fix, for sure.
Noriega7
03-04-12, 11:05 PM
Couldn't get an axle or even a boot through my work at car quest but I will definitely take that number from rock auto and try to cross it!
Noriega7
03-05-12, 10:51 AM
Went to order from rock auto this morning and says part is no longer available. Found same number on a site called daves discount autoparts but it says its for a 4wd front outer. Same part number shouldn't make a difference though. Has anybody heard of that place or have any experience with them?
darkman
03-05-12, 11:07 AM
I don't have any experience with that supplier, but if the cost is low it probably worth a shot. I show O'Reillys has a universal CV boot (Special Products No. 33001) that might work.
Noriega7
03-05-12, 12:21 PM
Ordered it through daves discount autoparts and has to come straight from raybestos. Double checked the number on raybestos' website and will work on 2004 cts-v.
Dan_Gurney
03-06-12, 12:14 AM
You might even try seeing if geforce1320 will sell you theirs, i would think they would work, (i don't have the measurements to know what their shaft sizes are vs stock though.)
Noriega7
03-06-12, 12:11 PM
I plan on just doing the boot for temperary then after I save the money do both g force axles. Has the full bmr anti hop kit but still has pretty bad wheel hop :( is the $500 price tag for 1 axle?
jbaldez
07-06-12, 03:51 PM
I am having the same problem. What part # did you use to order from Daves?
