: Some Interesting facts...
kcnewell
08-26-03, 11:27 PM
The following wandering thoughs were put down in answer to the ongoing oil consumption discussion and I thought that it might be good to get additional mileage out of it here, too. If interested, read on....
The comment was made about the variance in oil consumption on Northstar engines being more of a concern than the actual consumption of any given engine...thus the following comments.
Good point about the difference in consumption....
The real issue is the limitations of the production tolerances on the honing process for the cylinder bores. Size is no problem..they are all dead nuts. Surface finish is the issue. It is imperative that the "smoothest" possible surface finish from the process retain enough oil to not starve the top rings under continuous heavy load and high RPM. Unfortunately, to make the smoothest possible surface finish "rough" enough to retain oil...the resulting "roughest" or most aggressive surface finish the process is then capable of will contribute to a 1000 miles per quart or worse.
There is really no magic here. All the automakers have access to the same honing process and honing equipment manufacturers. Thus, they are all "stuck" with the same variation in production. As engine specific outputs have risen and the operating RPM of the engines have risen over the years all the engine makers have gone to a more agressive surface finish for proper oil retention. And all run into the same situation with variation in oil economy. If you do some reading and research you will find that all engine makers will state that roughly 1000 miles per quart is "acceptable" or "normal" in some fashion.
Not to say that the 'average" engine gets that oil economy...but...and engine that gets 1000 miles per quart will have absolutely nothing wrong with it at disassembly and inspection.
Fact is that the engines that tend toward the high end for oil consumption seem to look the best at high mileage...whether it is the higher oil supply to the top of the piston or the frequent spiking of the oil in the sump with fresh additives due to more frequent adds (or both) is up for debate.
Back in the "old days" of 350 cu in engines that made 180 HP it was entirely possible to make the cylinder walls mirror smooth and the engine would live and use virtually no oil. Won't work today with the HP over 1 HP/cubic inch and RPM up to 6000 continuos and 6500 RPM shift points. The top rings will not take it without microwelding to the ring lands of the pistons.
The honing operations have received many improvements over the years as technology in the honing arena improved. Today, diamond stones with a water based honing coolant is the norm for long life stones that do not change over time. The older processes with vitrous stones and honing oil change significantly as the stones break in and wear and the stones had to be changed frequently as they wore out...so each hone was going thru a continual cycle of break-in and wear out of the stones. Generally on a V8 two cylinders on each bank are honed at a time and then the other two are done in the next station by two other stones....so any given engine has 4 different honing stone sets in the differenct bores. Depending on what the life of the stones is and when they were being replaced there can be some variation in the surface finish (in regards to oil consumption) from cylinder to cylinder and bank to bank. Usually when the stones are new they make the most aggressive cut and leave the most aggressive pattern. The stones get smoother as they wear and the pattern gets less agressive. All the stones are "broken in" in initially on scrap blocks but there is obviously some change in the next several hundred blocks.
To put things in perspective, an average engine builder might hone one or two engines a week. A major NASCAR engine builder might do 400 or 500 engines a year..... EVERY DAY the engine plant that makes Northstar engines hones 1000 blocks...that's 8000 bores. And even more are done on a lot of days...the 1000 number is very loose. There is a great deal of process control placed on the cylinder wall surface finish but the inherent variences in the process will certainly lead to a considerable difference in oil economy in some engines...and absolutely nothing will be wrong with them.
Personally, if I could pick my engine from the line, I would go for one that uses about 1500 per quart. Seriously.
One thing that was done on the original Northstar engines was a process called plateau honing. In this process the cylinder walls are "marked" with a very agressive hone that leaves fairly deep scratches. The high points of the hone pattern are then smoothed with a second hone plateauing off the tops or tips of the "peaks". Under a micorscope this looks like a flat platueau with relatively deep, narrow crevices for oil retention. This process worked very well for oil retention and durability but was inconsistent for oil consumption to some extent. The current process has been improved with a more conventional hone that is not deliberately plateaued and is more consistent. Plus it uses the diamond stones that last far longer and are much more consistent over time.
The other thing that the modern engines sacrifice oil consumption for is friction. The thinner rings and lighter spring load rings are desireable for power, sealing of compression, less friction and lighter mass for less ring flutter at high speeds. Unfortunately, there is no free lunch here, and the lighter rings let a little more oil by.
The 2000 and later Northstar engines get hard anodized top ring lands to resist pound out and wear since the ring lands were moved closer to the top of the piston. One unfortunate side effect of the hard anodizing is the microscopic "pebbly" finish of the anodizing that tends to cause lack of seating of the SIDE of the ring to the SIDE of the ring land. This pebbly area will retain oil and cause oil consumption until the anodizing is polished smooth as the rings "break in" to the ring lands. The anodizing is hard, however, so that is why the "drive it like you stole it" advice works , particularily on later Northstars, to ensure good break in and sealing for less oil consumption. Many of the oil consumption complaint engines that have been analyzed at the factory had the anodizing on the piston ring lands virtually unscathed...as in never broken in due to gently driving and babying. The engine likes heavy loads, high RPM to break in completely.
The heavy load/high RPM also promotes ring rotation on the piston to keep the rings freed up and mobile. The oil comsumption complaints from the older Northstars typically come about due to ring sticking in the ring lands due to carbon buildup and the rings gradually getting stuck in place. they have to move to work. Keep them exercised.
Hopefully this rambling will shed additional light on the subject....
LakeDweller
08-26-03, 11:35 PM
Beautifully said...really. I now have a new love for my one-day "new to me" '98 Concours...
Thank you so much!
banstyle
08-27-03, 12:11 AM
Well thought out. Of course, my brain does the knee-jerk "that's-a-damn-good-explaination-and-because-you-sound-like-an-expert-its-probably-true" thing, but nevertheless, alot of what you say fits the missing pieces of the puzzle.
Thank you for your perspective! I think it will make me feel better about the 2 quarts I've lost over the last month!
kcnewell
08-27-03, 12:17 AM
I've seen 'em use more....How many miles were traveled in that month?
banstyle
08-27-03, 01:11 AM
I'd have to look.
I was driving back from a mountain trip (denver <-> grandjunction, total of 800 miles) and the Service Light came on. Was just low oil.
I changed the oil shortly after I got the car, which is now about 3000 miles ago. I'm changing the oil tonight.
elwesso
08-27-03, 06:57 PM
Wow..... If I normally give my $.02, he just gave about $5 worth......
jersey dude
08-28-03, 12:22 PM
Thanks so much for this detailed explanation of Northstar oil consumption. I am a complet MORON on anything mechanical-I just like the way my '99 Concours drives. However, I have never had a car EVER require oil between the 3,000 mile changes (at least that I knew of). Your information (Being a luddite I had to read it 3 times to get the gist of your explanation) is invaluable, explains a few things and puts my mind at rest. Thanks so much for spending the time to do so-totally appreciated!
AirJigga25
08-28-03, 04:06 PM
I also thank you for the explanation. My car uses about a quart per 1000 miles...and since I've been told this is normal, I've been fine with it for a while. My engine has a binge (oil) drinking problem...Now my mind is even more at ease. :cool:
kcnewell
08-28-03, 09:43 PM
That's what these forums are for.....Yes?
"Who shot cha, but you punks didn't finish, now you're about to feel the wrath of a menace" - 2pac
That's more than a little ironic....Considering who it comes from and where he is now.
Snyder81
08-28-03, 10:33 PM
I vote that the thread title is renamed to "Northstar oil consumption." This is a very interesting thread and I would like to be able to search for it later if necessary! Thanks OP!
AirJigga25
08-29-03, 08:45 AM
What are you trying to say.
I don't see any irony.
kcnewell
08-29-03, 10:25 PM
More than a little ironic that he's the one that wound up dead....Ya think?
Let's not drift off topic here....I've noticed that there's a lot of that in these forums ( very distracting )
Mad'lac
08-29-03, 10:44 PM
Is he really dead? I mean since his death he came out with more albums.
kcnewell
08-29-03, 10:47 PM
No more!.....This is way too off topic.
And YES! He's still dead.....Just like Elvis!
Mad'lac
08-29-03, 10:52 PM
lol I saw Elvis in here!!! He drives a Honda Prelude.
STSFreak
08-29-03, 11:34 PM
Elvis is dead?
AirJigga25
09-02-03, 10:55 AM
offtopic - maybe if you're just considering that quote its ironic. However, he new he was a dead man sooner or later because thats the life he chose to lead. He predicted his own death. His boy biggy got it too. RIP to them both.
BTW, since tupac's death other people have been releasing a lot of his music that he never released, just trying to cash in on him. A lot of his second rate stuff has hit the streets. What is really ironic is that both Biggy and Tupac were two of the best hip hop artists ever and they both died young, way before they peaked.
Katshot
09-02-03, 12:19 PM
I know I lost a lot of sleep after they got popped. :rolleyes:
AirJigga25
09-02-03, 01:23 PM
no you didn't. You were in your garage working on your cars.
tupac and biggie dying is comparable to Michael Jordan and Magic Johnson dying in say 1984.
kcnewell
09-02-03, 11:48 PM
Except Jordan and Johnson actually have some talent.
Mad'lac
09-03-03, 12:01 AM
Good comeback :histeric:
Katshot
09-03-03, 05:52 AM
What he said! A world with a couple less rappers? No downside I can see. :rolleyes:
It's kind of like the old joke, "what do you call 1000 dead lawyers at the bottom of the sea? A good start."
Mad'lac
09-03-03, 12:54 PM
Soo many rappers now that I can't tell the diff. Well not like I listen to it much anyway.
AirJigga25
09-03-03, 01:15 PM
I suppose this is all falling on deaf ears so to speak. No big deal. This is a Caddy website anyway. I could probably talk until i was blue in the face but wouldn't get anywhere.
Katshot
09-03-03, 02:40 PM
Affirmative.
kcnewell
09-03-03, 11:20 PM
Now you're getting the picture.
Allante North *
09-03-03, 11:25 PM
I think it a rule somewhere that rappers have to plagerize(sp) other peoples lyrics and or music.
At least Snoop Dog has "Girls Gone Wild" going for him. :offtopic:
Back to the Oil issue if we please.
Mad'lac
09-03-03, 11:28 PM
The last thing I wanna see while looking at "Girls gone wild" would be Snoop Dogg
botboy
09-08-03, 05:45 PM
Hi there. I'm a new member of this forum and I'm working on rebuilding a northstar out of a '93 STS and doing a manual conversion with the eventual goal of putting the engine into some sort of hotrod (right now my eyes are on a '39 Chev 1/2 Ton truck). This engine had over 100k on it so I'm going to rebuild the engine in order to prevent later hardship and problems, its a lot easier to work on the thing when its out of the vehicle than in it obviously. I'm probably also going to have the machine shop I have balance and rebuidl the bottom end do a valve job, port&polish and possibly port match the factory intake, at least until I can afford one of those beautiful aluminum intakes from chrfab. Since its a '93, it isn't OBD-II and I can also "chip" the motor with one of the kits on ebay or elsewhere (not just the stupid resistor-on-the-O2 sensor, one of the ECM changers)
I read your advice and it seems that oil consumption isn't a problem for people who "drive it like they stole it" on 2000-later northstars, well I'll be honest I do tend to go fairly high through the gears, and while I do my own maintenance and everything I do drive my vehicles a little hard. So I have two questions:
1. When the machine shop cleans up the bores, should I tell them to use an aggressive crosshatch pattern, or a less agressive crosshatch pattern? I'm looking for a reasonable centerpoint between performance and oil consumption, and I would prefer to not change or add oil any more often than I usually do (every 3k miles, dino oil)
2. When the engine is rebuilt, would you recommend using the later style (2000-up) pistons and rings, or the ones that are original to a '93? I didn't see any threads here, but are there better aftermarket rings/pistons for a northstar at reasonable prices? If so, do these have any advantages in oil consumption than the rings I can buy for it from a goodwrench dealer?
Katshot
09-08-03, 09:37 PM
Ask the machine shop about the pros and cons of the cross-hatch. And as far as the pistons/rods, I'd probably stick with the older style (higher compression) since you mentioned that the car is to be a hotrod. Again, I'd talk to the machine shop and pick thier brains.
