: Parts List for Timesert Repair
11-15-04, 01:02 PM
Hi I am planning on having my 1996 N* timeserted and would like to know if anyone has a parts list available for this. I want the mechanic to do any preventative maintenance work that cannot be done while the engine is in the car - gaskets, seals, etc... Thanks Jim
11-27-04, 11:48 AM
Check the block real good for oil leaks (1/2 case seal). If the case is seeping or the oil pan / oil manifold is leaking repair it when it's out of the car as it's a whole lot easier then if it's back in. Check the rear main seal as well.
96 STS
11-27-04, 12:12 PM
Not meaning to highjack this thread, but this is just an FYI question to educate me.
Since the engine/trans in Sevilles is transversely (sp?) mounted, which end is considered "front", the driver side or the pass. side?
96 STS
11-27-04, 12:30 PM
Front = end with pulleys ;)
No More Cadillac's
11-28-04, 12:16 PM
I am interested in finding out how long it takes to repair a blown head gasket including engine removal and install
