View Full Version : How to remove this pin on the trunk liner?
tigerlion
02-23-12, 03:44 PM
I am trying to remove trunk liner but I can not remove two pins look like this.
How can I remove this?
http://img1.fastenal.com/productimages/0162629_hr1c.jpg
http://www.fastenal.com/web/products/detail.ex?sku=0162629
vettepoweraddict
02-23-12, 03:52 PM
The easy way? or the persiration way?
Easy way.....Go to you local parts guy or dealer, and buy (2) new one of these. Then take a pair of diagonal pliers and snip off the top and push the peg thru the hole
Perspiration way..... Use diagonal pliers and work the plug up buy pulling on like a claw hammer without squeezing too hard as not to cut thru the barbed peg. You can work it..Swear at it a little and it will eventually will pull out. Bad news is it will not be the same and won't fit as tight when you re-use
tigerlion
02-23-12, 04:11 PM
Thanks vette! I am ordering the pin now.
Andringa
02-23-12, 04:19 PM
They make tools specifically for removing clips like that. I bought one for something like $5 that looks like this.
http://www.autozone.com/autozone/accessories/OEM-Upholstery-clip-tool/_/N-25qz?itemIdentifier=48579_0_0_
Looks like they make better ones that you could spend more money on if you wanted to.
http://www.clipsandfasteners.com/Clip_Removal_Tool_p/a15301.htm
