View Full Version : What are the best brakes for an 04 Deville?
cadillac kid1
02-10-12, 12:00 PM
I need front brakes, i'm told Ceramic is the best, but I have some people telling me that you can have problems with them, regardless i'm leaning towards ceramic, what do you guys think is the best? Thanks
RippyPartsDept
02-10-12, 12:45 PM
ceramic might make a little more noise than normal but they'll last longer and the difference in the brake dust is huge (almost no brake dust from ceramics)
Submariner409
02-10-12, 03:28 PM
Go to the EBC website - www.ebcbrakes.com (http://www.ebcbrakes.com) - and get to Automotive brakes, U.S. There are a slew of links to every possible sort of disc brke info you could ever want. Do a bit of homework.
I run ceramic pads on slotted rotors - no noise, no dust, wonderful braking in all weather.
Chris, doesn't GM make a set of slotted Durastop rotors with companion ceramic or semi-metallic pads ???
RippyPartsDept
02-10-12, 04:11 PM
some cars have 'performance' acdelco rotors available ... i would guess that those would be the slotted ones
the pads aren't matched to these rotors though... you could use whatever pad you want
at least as far as I know ...
http://images.wrenchead.com/smartpages/partinfo_resize/DCL/18A1180_Alternate1.jpg
SO.... looks like they're slotted AND drilled!
those are the 'specialty'/'performance' rotors for a 2004 deville (without the heavy duty J55 braking option that comes on livery cars with the 8 lug bolt wheels/hubs)
so basically for the regular devilles
LH rotor
19171339
RH rotor
19171340
ceramic pads would be ACDelco Durastop brand (professional grade)
#19111651
notdel
03-05-12, 07:27 PM
thanks for the info guys, I'm also thinking of upgrading brake pads and rotors. now i'm off to check prices.
Submariner409
03-06-12, 10:45 AM
Talk to Chris - Post #4 - Rippy Cadillac over there >>>>
For EBC, look at www.placeforbrakes.com - they now have a discount banner on the home page header, and their shipping is free. I run EBC Black Dash slotted rotors and the new ceramic Redstuff pads - glass smooth and no dust..........BUT you need to follow the break-in instructions.
Alifard
08-11-14, 01:31 PM
what front/rear rotors and pads do you recommend for 2001 DHS? And do you have them in stock? If so plz send me pricing as well
RippyPartsDept
08-11-14, 01:50 PM
I recommend any of the ACDelco/GM options for your vehicle
If you get me your VIN I will look up the choices for you
there are often three choices of each front/rear/pads/rotors
(ACDelco OEM, ACDelco Durastop Professional, and ACDelco Advantage)
keithss1
09-06-14, 08:43 AM
I bought off of Ebay ceramic pads and drilled and slotted rotors for all four wheels and changed them out my self over a year ago. What a huge difference in stopping distance, much less and no warping of front rotors and no brake dust covering the wheels. I have a 2004 Deville DHS and the front rotors would warp over time and you would feel the steering wheel "pulse" from the warping. You will notice a little noise (almost like a jet turbine whining up and down as the car is at lower speeds) coming from the car while driving because of the drilled rotors but in my opinion a very small tradeoff. I sent around $200 - $250 (from memory) for all four wheels.
Submariner409
09-06-14, 09:25 AM
Rotors don't "warp" - they're machined from gray cast iron for just that reason.
This is from Stoptech, a huge brake manufacturer. Other insight in the EBC Brakes website technical papers.
http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
