View Full Version : Rocker Panel HELP...
01-28-12, 11:53 AM
One of the clips busted on my passenger side rear rocker panel and I don't know how about fixing it. I know they're held on by a few clips and I can purchase them them through Luke, but I don't know how to install it.....do I have to break the rest of the clips and redo all of them or is there a way I can just fix the one that is broken? I appreciate any info or help, Thank you
01-28-12, 12:33 PM
As close as I can get is the wheelhouse liner. See attached.
01-28-12, 01:25 PM
Hey thanks for the info, i'll try and put it to use.
cts-v avino
01-31-12, 04:30 PM
Same thing happened to mine. I used 5 minute epoxy and pushed it in with a 2x4 against the wall in my garage to apply pressure. Just make sure you clean it the best you can with some rubbing alcohol.
02-03-12, 04:55 PM
I've fixed this before but it was a loooong time ago. I believe you have to remove the broken clip out of the rocker panel and slide/insert a new one. Once it's replaced it's literally a snap.
02-05-12, 10:55 AM
Nice, i'll just have order a clip from Luke and try just replacing the one....Thank you for the help!
