: Catalytic converter 05 STS v8
Kadillac Kreem
01-19-12, 11:09 PM
So recently check engine light has come on, I have taken my care to advance auto. They said I have an emission code being brought up on the diagnostic tool for a clogged Catalytic converter. I will admit I am guilty for putting 89 and 87 in my car and rarely 91 did not think much of it. The car is running good and everything, just curious any solution to cleaning the cat without having to install a new one? also what is the price and labor on a repair like this. Again 05 sts v8 90k on the odo.
Regards,
Kreem
caddyfat2
01-20-12, 08:10 AM
Hello Kreem. The cats in your 05 V8 are covered under an extended 200k mile warranty by GM. I had mines replaced for free last year so if you are having cat problems take your ride to the dealer for the free fix.:cloud9: ( If you need the recall letter I can fax it to you or anybody else upon request.)
Kadillac Kreem
01-20-12, 08:36 AM
You can email me at KreemGhandour@gmail.com much appreciated my fello Cadillac Owner.
BaTu
01-20-12, 09:56 AM
Also, I don't think the lower octane would contribute to the cats demise... AND GM recognizes there is a problem with these cats and has extended the 8yr/80K to a 12yr/120K warranty because of it. I have a letter from them offering a refund had I paid for a cat prior to that (I didn't) and explaining the expanded coverage....
Midnight
01-20-12, 10:11 AM
More Info on the Recall (from alldatadiy.com):
Vehicles Involved
Involved are certain 2004-2005 model year Cadillac SRX and 2005 model year Cadillac STS vehicles equipped with a 4.6L engine (LH2), and built within the following VIN breakpoints:
2005 STS From 50100074 to 50237744
This is for the extended coverage. If you're not in that range of VIN, I guess you gotta pay.
valjan1
01-20-12, 12:25 PM
I bought my 2005 cadyand i have 275000 kilometers .i have an issue with the cats and i just called GM this morning and it is true
that GM exended the garantee to 322000 kilometers even if i imported the car from the us.I live in Montreal Canada.
aung03
05-29-12, 10:10 PM
Hello Caddyfat2,
Can you be so kind to send me the letter to austin.ung@gmail.com ? i seem to have that problem, just got real bad today. thank you in advance
EChas3
05-31-12, 10:13 PM
I've read that only V8's qualify. If you're under 80k miles, you're covered under the EPA req. warranty.
parker34
01-22-13, 09:54 PM
Well mine finally decided to bite the bullet at 140,000 miles. If anybody still has the recall flyer/letter saved on their computer and can send it to me it'd be much appreciated. The link in the other threads says the picture file that had been uploaded is not there any more.
1BadCadSTS
01-23-13, 02:38 AM
It ONLY applies to the v8. Not the 6.
parker34
01-23-13, 09:10 AM
I have the v8 and my Vin falls within the range of the recalled cars. I just wanted the letter that was sent out but I will try to get a service set up without having to have it.
KRSTS
01-23-13, 11:37 AM
You don't need the letter. The dealer will look up the VIN and if it is eligible will fix it under the special warranty.
curtc
01-23-13, 03:29 PM
:yeah: Shouldn't have any hassle at all since it is special coverage, all you need is the VIN #.
fps_dean
02-13-13, 08:50 AM
I just had my check engine light turn on too. Nothing seems wrong with the car, so I am suspecting either a bad oxygen sensor, or from the sounds of it even more likely, a bad cat.
Thanks to you guys, now I know I should bring it to the dealer, as I am otherwise out of warranty (and the nearest dealer is miles away).
Edit: So sure enough, it is a bad cat. My mechanic pulled he codes for me.
Does anyone know, if one goes bad, would they replace both? My mechanic said the other can't be far behind, and the engine will run a lot better if both are balanced as well.
EChas3
02-13-13, 07:35 PM
I'd be VERY surprised if they'd replace a cat that met specs; even by .0001 of spec.
fruscadownerlo
06-09-14, 11:06 PM
Where can I get info on the extended warranty you are referencing? Thanks. DL
curtc
06-10-14, 12:27 AM
Just give the dealer your VIN, if it's covered they'll let you know.
cstarkey
10-03-16, 02:17 PM
Could you please send me a copy of the recall letter? My email is candystarkey@hotmail.com
