: Differential Fluid Question
mountainv
01-18-12, 01:22 PM
I have had no diff issues so far, but have noted the posts on V diff problems. I am running the stock Dexron LS fluid,
wondering if I should change to synthetic, like Mobil 1 75-90. Thanks for experienced advice!
M5eater
01-18-12, 01:29 PM
Can you? yes.
Should you for the sake of extra protection? No. Not unless you take your V to go racing often.
Should you change it at least once after a few thousand miles? Probally, but it's not going to fall apart anytime soon either way.
baabootoo
01-18-12, 01:35 PM
The manual says that it IS synthetic anyway. I wouldn't bother to change either, as long as the level is correct.
thebigjimsho
01-22-12, 06:59 PM
It is VERY easy to change. If you like to be very safe, no problems with doing it, IMO. If you got the time and the caek, go for it...
WhoseCadillacIsThat
01-23-12, 04:21 PM
Now I've heard of putting corks in there but never caek - I would probably eat that....
thebigjimsho
01-23-12, 08:35 PM
Love caek...
Unclemelty
01-23-12, 08:39 PM
Now I'm hungry...all this talk about caek....
GMX322V S/C
01-24-12, 10:26 AM
...Should you change it at least once after a few thousand miles?...From what many DIYers have posted, a fair bit of bedding material seems to come out at first change.
The manual says that it IS synthetic anyway.+1, although limited-slip additive is still required if you use the stock fluid (apparently there is a Corvette-spec synthetic that doesn't require LS additive).
I wouldn't bother to change either, as long as the level is correct. From my own experience, at less than 2,000 miles, I had limited-slip noise during low-speed turns after a cold start in cold weather (this was different from the PS2 crabbing noise). Fluid level checked okay. Changed the fluid with factory stock + additive anyway and the noise went away.
