: Need Help
01-08-12, 05:53 PM
Im trying to get some direction on my 1988 Birritz It died while driving the other night,after it died i tried to turn it over and did nothing,i checked the battery and all fuses and it still will do nothing.I am at the point now i believe it is either a fusable link,circuit breaker or perhaps a relay,if someone could give me any pointers i would be very greatful,I have never seen or heard of anything like this before.
01-16-12, 12:29 PM
Remove the battery cables from the battery. Clean them and reinstall. You say you "checked" the battery? Does this mean you verified at least 12.5 volts between the posts?
01-30-12, 02:35 PM
If your key has the little chip on it, then your problem could be the theft deterrent system and requires change out of the ignition switch.
01-31-12, 11:12 AM
Most folks dont post the repair! They get our insights and then never post back with the results to help others? I doubt the car is still not starting after 3 weeks.
02-01-12, 07:06 PM
They come and go when they need help.
