: 20x13 rear wheels
DxxB
01-06-12, 12:24 AM
Hi all,
What mods do I have to go through to fit a 20x13" wheels and 345/30R20 tires in the rear section of my CTS-V coupe?
The CTS-V has 12.7" free space for a wheel, but with the setup above, it will take about 13.5".
P.S its ok if they stick out. I like em like that.
Thanks in advance!
killer67
01-06-12, 01:49 AM
widebody kit
thebigjimsho
01-06-12, 09:40 AM
Stick out? yuck.
LV_V
01-06-12, 06:52 PM
That tire is way too big to fit IMO. More than an inch larger than stock and the width won't be possible to tuck into the fender without a widebody kit. And good luck getting a response from D3 on their widebody kits (I've sent several emails over the past few months that have apparently been lost in the wormhole).
A setup I have considered trying (when I get my V eventually) is a 19x12 rear wheel with a Nitto NT05 335-30-19. I think this would be as wide as you could tuck into the factory coupe wheels wells. I obviously don't have experience with this setup yet, but intend to be the guinea pig for it. I'm sure some "minor" mods are going to be necessary to omit any rubbing (pinning/cutting of fender liner, minor grinding of metal, etc). But I plan on making it happen. And by the way, this 335-30-19 is about the same diameter as stock and has a matching front tire that is 275-35-19 that will fit perfectly on a 19x9.5 rear sedan wheel... Perfect candidates for stock sedan wheel widening: throw the rear sedan 9.5" rim to the front and have the stock front 9" rim widened to 12" for the rear. Then just powdercoat the wheels to your liking, add the correct spacers, and you're good to go! :lildevil:
Squirlz
01-06-12, 10:16 PM
Maybe something like this:
http://www.pbase.com/dirawan/image/72120607.jpg
killer67
01-07-12, 12:39 AM
hella flush!
mberisha
01-07-12, 10:28 AM
:ill:
DxxB
01-07-12, 09:10 PM
Eww no XD those rims are wider than the tires so they would take this shape. Germans like em. But no, that's not what i want.
If I fit the 20x13 + 345 wide tires it would stick out about 0.8 inches which is not that bad.
http://image.musclemustangfastfords.com/f/9579199/0306mm_leadz+Ford_Mustang_Drag_Car+Rear_Side_Wheel _Stand.jpg
Anyways, How do the guys tuck really wide drag wheels into a car with no wide body??
http://www.corvetteflorida.com/photopost/data/500/Camaro_Drag_Car_3.JPG
Still if not possible, where can I get fender flares?
thebigjimsho
01-07-12, 09:50 PM
hella flush!84861
BI2011ESV
01-08-12, 07:11 AM
The way they do this is called tubbing. Cutting your existing rear fender wells out and replacing them with fabricated aluminum wells to accommodate the larger tires. But with the CTS-V, you may have to make other adjustments with the control arms. Just according to how wide you wanna go.
But I think with a 20x13 and a 345 tire you would be alright just tubbing it.
DxxB
01-08-12, 10:45 PM
This is exactly the answer I was looking for. Thank you very much BI2011ESV
ChasJr
01-09-12, 10:56 PM
Please keep us informed on cost...Sounds Expensive....
BI2011ESV
01-11-12, 08:10 AM
Yeah keep us posted and if you don't mind with prices and who did the work. I would probably be interested in doing the same. I would love to stick a 345 under the rear of my CTS-V!
Dr. Design
01-11-12, 01:28 PM
Hello,
Where are you located at? Mini tub is the only answer if you arent going to go widebody. Look at our Le Monstre Coupe we built. It has a 345 tire on it.
http://www.d3cadillac.com/wp/wp-content/uploads/2011/10/Le-Monstre-by-D3-5.jpg
Thank you,
Dr. Design
D3 Cadillac
Hi all,
Thanks in advance!
FLYING V
01-11-12, 03:34 PM
@ Dr. Design - the 345's look great on there!
LV_V
01-12-12, 01:13 AM
Where can we get more info (i.e. pricing, body pieces replaced, etc)?? I've emailed a few times looking for info. Looks amazing.
BI2011ESV
01-14-12, 08:53 AM
That coupe is badazz except the ricer wing. I would remove that and fast. Other than that, perfection is all I got to say.
WantaV
02-02-12, 07:40 AM
Only ricer if it doesnt serve a purpose. (See huge wings on FWD civics)
Rule12b
02-02-12, 02:55 PM
That coupe is badazz except the ricer wing. I would remove that and fast. Other than that, perfection is all I got to say. Normally I would agree with you. However, having seen it in person I can tell you that with the widebody, it looks appropriate and flippin' fantastic. I really can't emphasize it enough as one who hates wings like that. The car looks incredible.
