View Full Version : The Synthethic Oil Report
sub613
01-05-12, 01:32 PM
Been testing Castrol EDGE, an approved Syn.Oil for our STS's.(Sheriffs Badge)
Thought it would get 7500 miles, but alas and alac, IMO, 7000 miles tops.
But now testing Mobile 1 "Extended Performance"... Looking for 15,000.
Using Mobile 1, Oil Filter, M1-260 ! 5W-30 of course. Odometer 49,700
Sheriffs Badge=Starburst.
Have Fun ! :cool2::cool2::cool2:
mckellyb
01-05-12, 03:10 PM
How did you determine it was "used up"?
I have 6% left on mine, and while I'm going w/5W30 M1 this time around, I could change... I do like the idea of being able to rely on the monitor, however, even though I track everything by hand, anyway.
Greg00coupe
01-05-12, 08:21 PM
I believe it's according to the monitor OR once a year which ever occurs first.
ddalder
01-05-12, 08:55 PM
Unfortunately, if this conclusion is based on the oil life monitor, these results have no validity.
EChas3
01-05-12, 09:28 PM
LOL! The Oil Life Monitor will read the same regardless of the oil used. It's based on things like start/stop cycles, length of trips, RPM's, temperature and so on. It doesn't sense the breakdown or wearing of the oil.
When did Castrol start paying GM the licensing fee to be able to use the GM4718M spec?
ddalder
01-05-12, 10:12 PM
Exactly.
mckellyb
01-05-12, 10:46 PM
I'm tempted to send my oil for analysis a couple of times, to see how accurate the OLM is, but 10K mile changes...it looks like I'll get 10-12K per, based on my car/environment...is fine by me.
I do 10K mile changes on all the cars, though the W124 holds 8 quarts and gets dead dino C4 diesel oil. Don't know what it is about the W126 & W124 gasoline engines, but they seem to 'like' diesel oil.
What's really nice is, the new-to-me STS hasn't burned a drop, you know what I mean, since I bought it 'bout 10K miles ago. I love that.
ddalder
01-06-12, 12:09 AM
The results would be interesting. There is a built-in safety margin with the OLM so there should still be some useable life even when it reaches 0%, I'm just not sure how much. This of course would also be variable depending on operating conditions once you reach this point.
The other factor some don't consider too heavily is the quality of the filter. Poor quality filters may suffer internal failures making the rest of this immaterial. Personally, I use Mobil1 along with a K&N filter. I don't usually run below 10% before I have the oil changed. My STS gets about 8,000km between changes while my Bonneville with the LD8 Northstar will get about 11,000km.
mckellyb
01-06-12, 06:52 AM
I'm with you on there being a safety margin even at -0-. Probably 10-15%, at least. Like you said, though, completely variable.
I used to use Mobil 1 filters, but have moved to Napa Platinum ones. Fram is well-known in the motorcycle community to have had problems for decades with internal failure/disintegration.
dkozloski
01-06-12, 12:15 PM
The OLM system is accurate and reliable enough that it got Dr. Shirley Schwartz several international awards.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Board=1&Number=130036&Searchpage=1&Main=9644&Words=%26quot%3BDoctor+Shirley+Schwartz%26quot%3B+&topic=0&Search=true#Post130036
GreaseMonkey
01-06-12, 02:23 PM
Great link. He easily summed up what I try to explain to some of my non-car friends.
paden
01-07-12, 11:10 AM
I just want his 66 Chevelle with a 502
RippyPartsDept
01-07-12, 12:12 PM
http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/73808-oil-life-monitor-accurate-not.html#post687668
(http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/73808-oil-life-monitor-accurate-not.html#post687668)
One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine. <<<< does that paragraph get anyone else excited besides me? laugh.gif
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life montitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. NOt something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
Please...NOT ALL ENGINES ARE THE SAME. The example above is an excellent practical justification of why you would want to add EOS and change the 15W40 Delvac in the muscle car at 3000 miles max and yet can run the Northstar to 12500 easily on conventional oil. You must treat each engine and situation differently and what applies to one does not retroactively apply to others. This is where Amsoil falls short in my book by proposing long change intervals in most everything if you use their oil. It just doesn't work that way. You can run the Amsoil to 12500 with no concerns whatsoever in the late model Northstar because even the oil life monitor tells you that for conventional oil off the shelf. Would I do that to the 502 in my 66 Chevelle...NO WAY. Amsoil says I can though. Wrong.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.
The oil life monitor is not under the control of a summer intern at GM Powertrain per an earlier post....LOL Not that a summer intern wasn't compiling calibrations or doing a project on it but is under control of the lube group with a variety of engineers directly responsible that have immediate responsibility for the different engine families and engine groups. The idea that a summer intern was responsible for or handling the oil life monitor is ludicrous.....LOL LOL LOL
yeah yeah yeah i know... tl ; dr ... but just check the parts in bold at least
although the whole thing should be required reading for anyone who wants to talk about oil and GM's OLM
by the way i linked to a post by Ranger but he's quoting this forum's old guru
also, as I recall there's a few forum members who have been sending out oil samples to blackstone labs for testing and i think they said that blackstone is telling them that they can go a few thousand miles past the 0% OLM (based on their recent samples sent when the OLM was reading 0%)
sub613
01-07-12, 12:15 PM
Answers, I Didn't use OLM for this test, the valves were getting noisy,
the OLM still said about 38 % Left,
had about 7200 miles on this oil. I decided to change the oil.
Don't think I will EVER use Castrol again.
Pictures: Sheriff's badge & GM4718M Spec. Excellent post Chris ! :rockon::rockon:
848328483384834
