: Driver side bottom heated seat not working. All others fine.
Surgeboard2000
01-02-12, 01:43 PM
The driver side bottom heated seat does not work. The back heater works but the bottom will not come on. Is there a fuse for just the bottom or does one fuse work them all? It clicks when you hit the on button but nothing happens. Any suggestions on what to do?
hdmech
01-02-12, 02:35 PM
Hope this helps.....
Surgeboard2000
01-02-12, 03:55 PM
That is a great discription of how it all works. Since the back of the seat works do you think that the Temperature Delta Fault could be causing this problem? What could be the cause? I was wondering if there was a seperate fuse for the seat heaters. Thanks for the help.
hdmech
01-02-12, 04:43 PM
It sounds like the TEDs on the seat cushion are not coming on, maybe due to a fault in the temp feedback ? If this is the case does yours try to cycle through as decsribed ? Another common issue is the wiring at the connectors on the module which is located under the passenger seat , there have been numerous failures as reported on the forum. Search " heated seats" and you will find some additional pics on what to look for and where.
Surgeboard2000
01-02-12, 05:11 PM
I will.....Thanks.
