View Full Version : Driver door seal
bruisersdad
01-01-12, 09:18 PM
Need to replace door seal on 2005 STS. Anyone attempted this? Is it easy for a "do it yourself" guy?
M5eater
01-01-12, 09:21 PM
most door seals are crimp seals on a pinch weld or are glued on. either ones are about 4/10 on a DIY scale. There are almost no tools required, but doing it right takes time(to remove glue and such) and you need to be careful with alignment. Otherwise it wont lineup right with the other seals.
CTBB
01-01-12, 11:15 PM
If you're referring to just the rubber door-seal, definitely doable by the average do it your-selfer. Mine was worn out due to door misalignment, and easily replaced after having a body guy adjust the door.
Glenn
