View Full Version : Spec -o- fuel pump
MMNineInchNails
08-25-03, 01:31 AM
Can anyone tlell me the specs of my fuel pump? such as gph? eh? eh?
lux hauler
08-25-03, 09:51 AM
I looked at NAPA's online catalog and here's what I found....
Attributes: Fuel Pump (OE Mechanical Type)
Pressure Rating: 5.25 lb - 6.5 lb
Gallons Per Hour: 20
MMNineInchNails
08-25-03, 02:39 PM
thanks a lot lux! :p
lux hauler
08-25-03, 04:34 PM
That's what they listed as a replacement.
A factory pump may not be exactly the same but I would think it's close.
MMNineInchNails
08-26-03, 02:13 AM
just wanted to know because i'm going to put a holley electric fuel pump on. probably the 97gph one...
davesdeville
08-26-03, 02:51 AM
That seems like overkill, even on a 472.
lux hauler
08-26-03, 03:04 AM
Check the fuel pressure recommendations for your carb. If the pressure of the pump that you get is more than is suggested for the carb, put a pressure regulator in line.
MMNineInchNails
08-26-03, 04:35 AM
overkill? pshhh. My friend put an electric fuel pump around that level, mabye more on his 430 with a 750 carb(same as mine)
