: Want the 2-way remote start key fob....could I just buy and program?
BlackDynamiteCaddy
12-29-11, 01:09 AM
Hi all,
Would buying the 2-way remote be as simple as programming it w/ my Escalade? Or would I have to have the dealer install this?
MrHolland
12-29-11, 01:17 AM
I believe there are different types of remotes, but once you get the proper one for your car I believe then you can program it. Heres some info from another post-
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-2007/248048-lets-talk-key-fobs.html
prosseda
12-29-11, 11:36 AM
The display will not work unless you install the additional module that goes the the 2-way remote.
murphy
12-29-11, 07:27 PM
You must have the dealer install and program. I purchased it for my '07 and regretted it. Range was only so so better..two way was nice but it was costly and the remote is fairly large. You can do better with the aftermarket units out there which will also not limit you to only two starts.
MrHolland
12-29-11, 07:58 PM
I'm sorry I wasn't thinking when you said two way remote. My misunderstanding, I was thinking regular fob.
davidmalky
10-22-13, 07:19 PM
I just purchased a set of 2 upper-class key-less remotes from ebay from seller named "remotes.inc". for my 07 escalade.
cheapest price around and has fantastic service.
his rating is way up there presumably because others are having the same great experience. was able to program in under a minute.
would recommend to all
thank you so much and keep up the good work
154914
here is the link to the ebay item www.ebay.com/itm/300914349897?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
wesyder
10-23-13, 07:56 AM
I just purchased a set of 2 upper-class key-less remotes from ebay from seller named "remotes.inc". for my 07 escalade. cheapest price around and has fantastic service. his rating is way up there presumably because others are having the same great experience. was able to program in under a minute. would recommend to all thank you so much and keep up the good work <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=154914"/> here is the link to the ebay item www.ebay.com/itm/300914349897?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649those are nice, i will be acquiring some in the near future
pinoyfiend
10-25-13, 12:21 AM
+1 on the upper class keyless remotes. Also got them from ebay seller "remotes inc". Got them in two days and programmed in 5 minutes...
