Tudds
11-08-04, 11:50 AM
Damn thing keeps blinking... how do i fix it without taking it to the stealership?
| View Full Version : 2004 Deville Tire pressure sensor-how to fix Tudds 11-08-04, 11:50 AM Damn thing keeps blinking... how do i fix it without taking it to the stealership? caddydaddy 11-08-04, 12:57 PM It should still be under warranty, unless you have over 50k miles. mastertech 11-08-04, 01:27 PM Have you had any tires replaced? The tire stores are famous for breaking the sensor when they break down a wheel and tire. If not, you can try a reprogram with your key fob and a magnet. Turn ignition to on position and hold down lock and unlock on your key fob until you hear a horn chirp. Then starting with the LF tire, hold magnet as close to tire pressure sensor(valve stem) as possible. You should hear a horn chirp after a few seconds. Then repeat with RF,RR, and LR in that order. You should hear a double horn chirp after LR, indicating the procedure is complete. If that doesn't work, you need a new sensor. Obviously, make sure your tire pressure is set before reprogramming. Tudds 11-08-04, 04:13 PM Have you had any tires replaced? The tire stores are famous for breaking the sensor when they break down a wheel and tire. If not, you can try a reprogram with your key fob and a magnet. Turn ignition to on position and hold down lock and unlock on your key fob until you hear a horn chirp. Then starting with the LF tire, hold magnet as close to tire pressure sensor(valve stem) as possible. You should hear a horn chirp after a few seconds. Then repeat with RF,RR, and LR in that order. You should hear a double horn chirp after LR, indicating the procedure is complete. If that doesn't work, you need a new sensor. Obviously, make sure your tire pressure is set before reprogramming. thank you so much BeelzeBob 11-09-04, 01:10 AM Not to change the subject, but.. Ya know Tonio? You're the last person I'd ever expect to see here.. What are you doing with a DeVille? | |
