: FYI- there's a bulletin on diff whine while coasting
M5eater
12-28-11, 03:44 PM
Just got off the phone with the dealership, there's acutally a new TSB on diff whine while coasting from aprox 60-40 down to 20 or so. He detailed a procedure that involves removing a bracket from the assembly and shaving material off to eliminate the noise. So if you've got a good service tech, there's now a fix for it. :thumbsup:
I know some people will probally want the acutal TSB number; I'll try to get that for us when I get at the place around 5 or so.
Houdini
12-28-11, 04:16 PM
This one? Yeah see if you can get them to print it out for you including repair procedure.
Service Bulletin Number:
SB-11084
NHTSA Item Number:
10038765
Summary:
GM: 2011 CADILLAC CTS. THERE IS A WINE OR HUM NOISE COMING FROM THE REAR DIFFERENTIAL ASSEMBLY AND THERE IS A PROCEDURE TO FIX IT. *RM
M5eater
12-28-11, 07:28 PM
so I didn't notice it before, but what I was handed is a bulletin for 2011 AWD models.. I'll have an update tomorrow..
if someone is able to check to verify that this applies to CTS-V's the document ID 2680007
PI0350C
GM-4-LIFE
12-28-11, 08:12 PM
Glad I got GM to replace my entire diff, but let's hope the noise doesn't develop on the new diff as well. GM really should make it highly recommended to flush out the diff and fill it with fresh gear oil at no more than the first 500 miles to avoid this issue altogether.
M5eater
12-28-11, 08:27 PM
lets hope they haven't done what the bulletin they gave me instructs them to do; cut into the center driveshaft support .
GM-4-LIFE
12-29-11, 02:22 AM
Yeah, no kidding!
Cadillac Cust Svc
12-29-11, 10:36 AM
Any update from the dealer today?
Breanne
Cadillac Customer Service
M5eater
12-29-11, 10:44 AM
I called them today to ask them to double check the TSB. I was informed that he would take it up with the tech (it's their senior tech) but that they usually run the bulletin search via VIN and sometimes all applicable vehicles are not listed on the TSB .
lilred
12-29-11, 12:18 PM
This is what I've got with my car, so I'll watch this thread with interest. I haven't brought mine to the dealer yet since it's not affecting the performance. Mostly just annoying.
M5eater
12-30-11, 09:34 PM
So, they did get with tech-line and the acutal TSB for this issue is; PIP3051F
document ID 2696048
howl / whine noise from rear axle... july 28 2011
vehicles affected;
2003-2012 CTS
2004-09 SRX
2005-2011 STS
06-10 Solstice
07-10 sky
condition or concern:
howl or whine noise from the rear axle and/or decel. The noise is most noticeable at speeds between 35-50 mph
There is no repair for this issue, the noise is normal.
